Awlgrip or Duratec
Results 1 to 10 of 10
Awlgrip or Duratec
    fastflats
    Columbia, Mo
    Default Awlgrip or Duratec
    I apologize if this has been addressed before. I looked thru floor repair threads & could not find any info regarding Awlgrip. Anyhow, my paint supplier is telling me that Awlgrip is better for flowing out the floor in my Canyon flat once repairs are done. He said I can use black Awlgrip on black areas, then flow out with clear coats once black starts to kick. I have used neither product before, but seems that everyone is using Duratec so why should I try something different??? Anybody have experience with Awlgrip compared to Duratec? Thanks so much!!!
    Senior Member Old School's Avatar
    Feb 2009
    Both in Fla. and Orange,Ca.
    Forget the Awlgrip, it is mainly a yacht paint, if going to do Duratec Clear mix 50/50 black gel with Duratec shoot black, then after kicks clear all you want to have clear coated, Duratec flows out very good as well i use it all the time, My RaysonCraft did not even need polishing after shooting floors..and it looks great Black Stringers and center section with nice wood floors.
    Speed cost money...how fast did you say you wanted to go
    1970 RaysonCraft LP SE-54
    West Mich
    Awlgrip is great stuff and very durable and not to mention that it can be bushed on .
    West Mich
    Quick note Imron is a great alternative and can be brushed on also which I often use for the bilge , hatches , etc using no thinner other then activator applying three coats after all is said an done 1st coat is a tack coat , apply second coat and let it tack & finish it off with a third coat letting it totally dry to touch .
    fastflats
    Columbia, Mo
    Default Thanks!!
    Quote Originally Posted by offshore ginger View Post
    quick note imron is a great alternative and can be brushed on also which i often use for the bilge , hatches , etc using no thinner other then activator applying three coats after all is said an done 1st coat is a tack coat , apply second coat and let it tack & finish it off with a third coat letting it totally dry to touch .
    . You guys are awesome!!
    Jan 2017
    Quote Originally Posted by OFFSHORE GINGER View Post
    Hey OG....You can still get Imron?
    Jan 2017
    Quote Originally Posted by Billy B View Post
    BTW....Happy New Year
    Mar 2010
    Redding,ca
    Default Awlgrip
    Question About Awlgrip? What style or part number do you use? Was looking to use this. Just making sure I get the right stuff.
    Thanks ray
    West Mich
    Quote Originally Posted by rayray View Post
    Thanks ray
    Every color has a different number or name . Awlgrip Topside Paint
    Mar 2010
    Redding,ca
    Thanks ray
    thanks for the info. I am trying to fix up the floors in my dads hondo flat bottom. I think only need the clear top paint. I was not sure what style or kind guy she have used. Thanks again.
    Ray
