Gel quantity
Results 1 to 7 of 7
Gel quantity
    Default Gel quantity
    What would be a general ball park quantity for regel of a southwind tunnel dragster. Black with clear on top. I am thinking of re-gelling Money$ucker and cutting down the pod. Just looking for a ballpark.
    Between black and clear should I wetsand to knock down any orangepeel?
    Vinyl Graphics, Magnetic signs, Reg #s, Boat names, Banners, Boat decals, Etc. Please contact me Via facebook or e-mail cycodesigns@hotmail.com.
    valley springs, ca
    are you going to add duratec to your gel as a additive. it will help smooth it otherwise it will look like a cantaloupe peel
    As much as I love wet sanding, It sounds like a good idea using duratec. I have no experience with Gel just paint.
    West Mich
    Hey guy working with jell is a lot more forgiving but more work then paint and just curious do you have a primer gun?
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Hey Cy, Gel the boat black (Catalyzed), then do a 75/25 Valspar clear TX-2 Gelcoat to Prestec clear top coat, mix them together as if it were one product of clear coat, 20CC's per qt.
    If this didnt make any sense, call me up, ill explain mo betta!
    Quote Originally Posted by TRG View Post
    I can do you one better. I will pick up the material from you with an instruction sheet.
    TRG
    TRG is offline
    No problem Cyco Designs, you know.....you and I really should not be friends, considering what I do for a living and what you do 50% for a living?
    It kind of contradicts itself a smidge! Ill get over it!
    Is this for your SWTD?
