I have a '78 Nordic Tunnel jet and I have questions about the stringers and floor. In the engine area where the rails mount there are areas on the stringers that has some delamination. I cut away a small area of fiberglass and the wood seems solid. I can't see or detect any rotten areas, even around some of the holes where the rails mounted (it does have a few "extra" holes). It also has balsa on the floor on the outside of the stringers that seems to be in good shape. So what are my options? Replace the stringers and balsa? Grind/remove the fiberglass on the stringers in the engine area, remove the balsa in the same area and re-glass the stringers and put in new balsa in that area? Any input would be greatly appreciated.
LinkBack URL
About LinkBacks
