how much dutatec to flow coat floors
Results 1 to 2 of 2
    Aug 2009
    Default how much dutatec to flow coat floors
    Wondering how much Duratec I will need when re coating my floors? I plan on going up to the top of the gunnal's and doing the transom and bulkhead. I don't want to run out right in the middle.I was planning on using the Duratec highgloss top coat (904-040) and thinning it with the high gloss additive #904-001. Has anybody thinned it with the gelcoat additive or should I use MEKP solvent to thin it? Also what size tip should I use in a HVLP gun?
    Carlsbad, Long Beach, Big River California, United States
    Quote Originally Posted by flatnasty View Post
    when I did mine, I sprayed it with a harbor freight HVLP, thinned with acetone. Came out good for my first time. Used the standard tip size, whatever it is. I used a quart and only did the bilge.
    1978 Southwind Tunnel Dragster
    LS powered
