replacing floors... epoxy opinions......
Page 1 of 2 12 LastLast
Results 1 to 14 of 17
    Sacramento Ca.
    Default replacing floors... epoxy opinions......
    i gutted my floors and now i am looking for an epoxy based resin to do my floors and stringers.
    TAP Marine Grade Epoxy System: TAP Plastics&
    this is what i am looking it i can get it local its gonna run about $180 for 1 gallon of marine resin and hardner b #143 due to winter tempratures...
    i figure ill most likey use 2 gallons?
    is there anything comparable but maybe cheap on the wallett?
    opinions guys i wanna get this done asap.
    Matt 74 tahiti 468 olds 72 mph.
    http://img.photobucket.com/albums/v31/matt1840/sig.jpg
    I bought mine local at a company called clark craft for about1/3 ofm your cost. Check their web site
    Oct 2010
    661 So. Cal.
    Default Tap
    I use tap resin/products and they are well worth the money. To give you an idea of how far the resin goes I did the whole cap on my 18' Sanger with only 1 quart of resin.
    SJ
    Senior Member bigdog's Avatar
    Feb 2009
    MANTECA
    Default Resin
    There are places that will ship it to you for much cheaper than that. Tap is very proud of their stuff.
    try this place: www.fiberglasssupply.com
    Lake Havasu az.
    Looks like about $65 for 1.5 gal for what you are looking for and $15/10lbs shipping
    Epoxy :*Epoxy Resins and Hardeners
    Originally Posted by gn7
    I'll concede, but
    David Olsen of Tamarc Fl. tricked his mother into giving him $27,272.50 and yet refuses to help his 94 year old mother in any way.
    Dec 2010
    Alabama
    Quote Originally Posted by Sold honda.bought hondo View Post
    I'm using West Marines "West System".
    Get the metering pumps, it makes measuring the proper ratio and no brainer.
    They will ship to your home or you can get it at their stores.
    Member 08VMax's Avatar
    Jan 2011
    Benicia, CA
    Quote Originally Posted by 77GT View Post
    Me too!! I'm a big fan of West System!! It's easy to work with, no smell!!! For one gallon from a store plus hardener you're at $141.00, for the resin and hardener plus tax, pumps are 14 but you only buy them once, they last a while and you can leave them in the cans when not in use, no need to remove to cap the cans!!! Plus tap doesn't have the pump system, soooooo much easier!!!
    Salem,Or
    Quote Originally Posted by 08VMax View Post
    Me three,
    thats what I used when I reglassed the stringers and put in a new floor on my 79 tahiti
    With Spray there is a way!!!
    valley springs, ca
    I use vinylester resin. not as expensive
    Jan 2011
    Benicia, CA
    Quote Originally Posted by sangerfan76 View Post
    Never heard of that.. Like the polyester just.....?
    Senior Member Untamed 777's Avatar
    Sep 2010
    Central Oregon
    Default Vinylester
    Vinylester is stronger than Polyester and you can use Duratec for the topcoat with epoxy you can not apply Vinylester or Polyester on top of it.
    Team Untamed 777 T/E
  13. #12
    Aug 2009
    Can you apply Duratec over epoxy resins? I've never used their products or flowed a floor but had intended to use West System or Epon epoxy resin on my floor project.
    Thanks,
    Mike Bruns
    Celina,OH
  14. #13
    Sep 2010
    Central Oregon
    Default Duratec
    Quote Originally Posted by firemanmike2127 View Post
    Thanks,
    Mike Bruns
    Celina,OH
    Duratec is Polyester so it's best to apply over Vinylester or Polyester. Epoxy I think is harder to work with and more expensive. Like one of the guy's said fiberglass supply is you’re best bet, they get it to you right away and the price is right.www.fiberglasssupply.com
  15. #14
    West Mich
    Hey guy , Epoxy is the only way to go ...which is a product that i have been using for over 40 years now and to tell you the truth why would you even want to use Poly or Vinyl considering there are epoxies out there that will give you a longer pot life ...........which means a longer work time with no stank ! Hey guy ,Duratech makes a primer that is compatible for epoxy which i used at Skater and still use today or should i say is a staple ......when doing fiberglass repair using Epoxy . Hey guy just a quick mention and that being is...............i think there are better places in your area to purchase materials from .
