What is the best way to strip paint off my fiberglass hull?
Results 1 to 14 of 14
    Senior Member pilot940's Avatar
    Chandler, AZ
    Default What is the best way to strip paint off my fiberglass hull?
    I had a paint job go bad and am now wondering the best way to strip the paint off the fiberglass without digging into the hull much?
    Any ideas???
    The only way to be safe is to completely start over. DA it down to a clean substrate. Re-prime and move on. Its sickening to sit and look at all that money in the form of dust on the floor, but it happens.
    Wet
    Wet is offline
    East Hampton, CT
    It depends on how many coats of paint you're talking about.
    Ill look around , but there is a peroxide based stripper that we use at work(aviation) thats harmless to any composites,,,Works fantastic, and will not burn your skin,,,,
    Quote Originally Posted by Wet View Post
    Oct 2010
    661 So. Cal.
    Default Stripper
    Kleen-Strip sells an aircraft grade stipper specifically made for use on fiberglass. when I stipped my Sanger I used a DA and lots of sandpaper.
    Chandler, AZ
    DA?
    Senior Member RogerThat99's Avatar
    Aug 2010
    Roseville, CA
    Quote Originally Posted by pilot940 View Post
    DA?
    Dual Action Sander. It spins and shimmies side to side and/or up and down.
    Orlando.FL
    Try oven off
    Lake Havasu az.
    You should try one of these
    Gear drive orbital sander..$120 ebay they oscillate and rotate at the same time...runs way smooth...even at low speeds....big flat 7" pad....it cuts way straight...i have glued everything from a 16 grit grinder disc to 600 wet/dri to mine...strip paint..bondo work...sand wood ok.....220-320-400-600 on aluminum to prep for polish...uses less air than a da...quieter....doesn't blow dust around as much as da....i glue sandpaper on with 3m spray glue,
    take it off with heat lamp or propane torch...i've owned 2 in last 20 years..never wore one out..the pad will bend if ya drop it...straightens with a hammer...My last hydro had old school crap graphics....thick...cracked.. A1 aircraft barely touched it..
    Glue a 40 grit and cut most of it off...1 piece of paper and finished with 80 grit...Even paper last longer..doesn't seem to fill with cut......if you are carefull you can color sand paint/clear coat with 600/1000 on big flat areas
    I know..sound like sales pitch..
    Find somebody who has one..use it for 10 min and you will throw a da in the round file..
    So like yes..it will strip paint just fine......or you can just stick 36 grit paper in it...run it over what you want to strip and scratch the hell out of in..then brush stripper on...the scratches gives the stripped a place to bite into..strips way faster
    Originally Posted by gn7
    I'll concede, but
    David Olsen of Tamarc Fl. tricked his mother into giving him $27,272.50 and yet refuses to help his 94 year old mother in any way.
    Chandler, AZ
    Nice, thanks, I knew it was something obvious...
    valley springs, ca
    light it on fire. lol just make sure any stripper you use is gelcoat safe
  13. #12
    Wet
    Wet is offline
    East Hampton, CT
    Soda blast, it's the shit.
  14. #13
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Key words here are "Paint job went bad" the paint im betting is not that old, so a light stripper will do just fine, so need to bust out the mud buster or aircraft heavy duty im thinkin, just run to the depot and grab some jabsco/jasco however you spell it, remember that water neutralizes it, so I would recommend keeping a bucket of water near by with a rag or something, do 2-3 Sq Ft areas at a time, and youll be fine, a light sand for primer and youre off.....again!
    if the paint has been on for a while, go with the Aircraft stripper, I dont think a media or soda blast is needed, that could be a bit excessive, not to mention the mess, same with the sanding technique, both are useful, but more work than anything, at least using the stripper, you can still hold a beer in one hand!
    learned a trick from another painter around here, keep the (Stripped) paintjob in a cardboard box, keeps the mess contained and to show the customer what the old paintjob looks like, puts into perspective how much $ goes into such little product!
    These are just my thoughts, theres more than one way to skin that kitty, some use razors and lazers, others use wax!
  15. #14
    Wet
    Wet is offline
    East Hampton, CT
    One thing to add...
    If you're going to use the stripper method, stock up on the plastic grocery bags. When you apply the stripper, put the bags over the stripper and give it a little pat down. Leave the bags on the stripper. This helps to keep the working vapors on the paint. It will not eat thru the bags and can reuse them.
