laminate adhiesion
Results 1 to 8 of 8
laminate adhiesion
    valley springs, ca
    Default laminate adhiesion
    just curious what everyone is using to adhere the laminate to the floors . i have used resin and also high strength adhesives. both have good and bad.
    West Mich
    Quote Originally Posted by sangerfan76 View Post
    hey guy , could you be a little more specific on your laminate and what type of material you are using or trying to laminate .
    UMPBA.ORG sleekcrafter's Avatar
    Polyester resin here.....36-50 grit for the tooth, and beveled the edges on a table saw.
    Some folks add a layer of mat under the laminaton too, to minimize trapped air.
    valley springs, ca
    i used red oak non paperback laminate its 1/16 thick. i bought a a cabinet shop
    Are you glassing over it with mat and cloth too?
    valley springs, ca
    ya i used 1/2 oz mat over the top
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Are you covering a shit area, or is this new wood over non existent wooded area?
    if you are covering old balsa that is cracked out or other issues, you will find that most likely that the problem will show up sooner rather later (Generally speaking!)
    Ive used the thin lam on transoms of Birds eye maple, turned out real nice IMO, one thing to remember when dealing with the thin stuff, when its wetted down, the Knots are prone to becoming weak spots if you feel the need to play with it, this was my problem in dealing with the Maple product.
    Good luck and throw up some pics!!
    valley springs, ca
    no after the stringers were re-glassed and sanded down I used thin laminate over the whole stringer. this is just for beauty and not structural
