How to find a water leak in the hull
Results 1 to 5 of 5
    Member Turbo Dan-O's Avatar
    Dec 2010
    Middle Tennessee
    Default How to find a water leak in the hull
    I am having a hard time finding where my 79 Taylor SS is leaking at. It's leaking somewhere under the floor and filling up the bottom of the boat. I have filled the boat up with water and it does not leak out anywhere. I epoxied most everywhere I thought it could possibly let water in but it is still taking on water. Any ideas of how I can get this thing sealed up?
    Dan-O
    okie, lake Texoma
    Quote Originally Posted by Turbo Dan-O View Post
    Dan-O
    Its probably leaking around the packing glands were the shaft goes through the pump, it will leak much worse while the engine is running or your moving. Just tighten the nut on each side about a 1/2 turn and see if that doesnt help. It will need the packing replaced some day but usually you can just tighten them, good luck, Hass.
    130.7mph in about 7sec , from an idle.
    http://www.youtube.com/watch?v=bbrazVxN1X0
    Oh, wait a minute, if I run too fast I'll be disqualified, ........no lake boater ever said.......
    Racing is who gets there first, not who gets there on schedule.
    H8-2-W8
    Carlsbad, Long Beach, Big River California, United States
    if you think its leaking from some hardware like the intake or something, grab your garden hose and start filling it up until it leaks out.
    1978 Southwind Tunnel Dragster
    LS powered
    Senior Member ugly duck's Avatar
    Jul 2010
    OGDEN UTAH
    Quote Originally Posted by sandeggo View Post
    simple and effective
    (GN7)Just a simple waste of perfectly good sour mash. If you need a fuel, use something that will poison you, not something that makes you buzzed.
    Sep 2009
    Quote Originally Posted by ugly duck View Post
    you both missed the part where he states that he has filled it up and it doesnt run out anywhere. I would check the packing like hass said and maybe your bowl gasket is leaking under a load leaking more water the more throttle u give it?
