Hull fix
Results 1 to 2 of 2
Hull fix
    May 2011
    Newville, Alabama
    Default Hull fix
    I want to remove a jet pump assembly from a boat I have.whats the best way to fix the hole in the bottom and have the bottom still be structualy strong..any help would be appreciated
    UMPBA.ORG sleekcrafter's Avatar
    Bevel back the insides, form a piece of aluminum, and tape it to the hull. This acts as a form, for the new laminations. The bevel or taper that has to be done in prepp is key to a good repair. Once the inside is laminated, the hull will need to be flipped, for the outside repair work. While upside down, the area needs to be ground out to a taper or bevel, and then start lamination repair on the outside. Grind, sand, and finish as desired. Jet boat hulls are thicker on the bottom than most hulls, this should give you a solid repair if doing it your self.
