eddies pictures
Results 1 to 7 of 7
eddies pictures
    Aquacraft Eddie's Avatar
    El Paso TX.
    Default eddies pictures
    I think i posted my pics, not sure yet but anyway if the pics come up, you can see the stringer, some of those holes were already there, i just drilled into them to see there was rott, I had a shop in arizona tell me that it will cost 2,000.00 to replace both stringers, but it might be more. The other question i had, was ,,, the stringers go up under the bow and there is hardly any room at all under there, how do they replace them under there? I hope they dont have to cut the bow off,,,, I havnt decided if iam going to let them do the work, I want to make sure its done right, plus that seems pretty expensive,, but then again I am new to the boating thing so maybe thats not expensive???/
ID:	123435   Click image for larger version.
Name:	stringer that has bubble.jpg
ID:	123436   Click image for larger version.
ID:	123437   Click image for larger version.
ID:	123438   Click image for larger version.
    El Paso TX.
    Default eddies aqua craft shark
    now that I know how to post the pics, i cant stop!!, sorry, these are kinda bad pics to. The boat is a 1971 shark, evrything is good , except the driver side stringer, has some rot that goes about two feet from the transom forward, just befor the motor mount.,, not sure exactly how rotted though? some brown but wood is still strong it seems,,if you poke it with a screw driver where a hol is, it seems strong. The boat has not seen water since 1986!!!!! the stringer got rotted from some exposed holes in the stringer that were never plugged. any thoughts????/ other than selling it????/
ID:	123447   Click image for larger version.
Name:	boat strakes.jpg
ID:	123448   Click image for larger version.
ID:	123449   Click image for larger version.
ID:	123450   Click image for larger version.
    Senior Member mdsheppie's Avatar
    Jun 2010
    Michigan,The State Of Confusion
    Dig out the rot then use this its strong and hard to grind but for a shark what the hell....
    El Paso TX.
    so you think this is better than injecting epoxy resin in it?? or would it be beter to replace the stringers? i was told 2,000.00 to replace, not sure if it is worth it?? where can I find that stuff????
    Quote Originally Posted by mdsheppie View Post
    Jun 2010
    Google search
    El Paso TX.
    cool ,, Ive never seen this stuff, but its worth trying, thanks for the help, im still contemplating replacing the stringers but if its not needed i wont, I wanted to keep the boat because it was my dads, just want to rebuild it the right way....
    Google search
    Jun 2010
    Quote Originally Posted by Eddie View Post
    check in v-drive section on here and look up the thread -the journey begins it has alot of useful info and you will have to rewrap the stringers in those areas but thats no big deal
