Crack in fibreglass.... Suggestions of repair method?
Results 1 to 10 of 10
    Senior Member BAHNER79AUSTRALIA's Avatar
    Jan 2010
    Australia, N.S.W.
    Default Crack in fibreglass.... Suggestions of repair method?
    Hi all, thought i would post up another thread. I have a crack issue on the top of the shell, right on the top edge of the hull where it begins to peak, then heads down on the inside. Was wondering if anyone has any advice how to repair. I can V it out no problem, and fill with fibreglass filler.... But should i attempt to lay some glass/mat on the inside? Its quite tight up in there..... Did a quick sketch showing a cross section showing what i mean. Just thinking it might need more strength than just V grinding it out and filling......Any suggestions? I have this exact crack on both sides of the boat.
ID:	135235   Click image for larger version.
ID:	135236   Click image for larger version.
ID:	135237   Click image for larger version.
Name:	Cross Section.jpg
    If its too loud.... Your too old....
    Senior Member Sanger-Spectra's Avatar
    May 2010
    Quote Originally Posted by BAHNER79AUSTRALIA View Post
    1 word GRIND, you will need to grind that out well past the fractured area and reglass with matt and cloth. Dish it out good and layup on the inside and outside.
    Jun 2011
    Dallas Tx
    How " Holorinhal " explained it to me and how he fixed some of the crack on his resto of the kona with v grinding " V-grinding is simply that you are making a cut, with a grinder and a carbon cutoff or grinding wheel, in the shape of a V. If You were to take a cut and turn it up and look at in cross section, it would look like a v,smaller at the bottom of the cut and wider at the top. The way you achive a v cut is to simply follow along a crack with the grinder, holding it slightly on its side, at an angle relative to the top of the crack, making a couple of passes with the grindre angled one direction and then the opposite angle direction. all v grinding does os gives the the stress crack some depth and body to expose raw glass and add new material to reinforce the all ready stressed area.Just be carefull on the depth that You grind down as not to grind completly thru the glass thickness. Thry to achive a width at the top of about 1/2" to 1" width then surface grind back past the V edge,in each direction, to a total of about a 3" width for the bite of the last layer of glass. when laying in the fiberglass cut alternating strips of mat and cloth starting with a skinny strip of mat wetted with resin and layed in the bottom of the cut and getting larger or wider fo each successive layer. In other words each layer should be slightly wider than the last until the last layer covers the 3" surface ground area the enttire length of the crack. Remember to grind out the crack a litle longer in each direction past where the crack ends to help stop the spreading of the crack. Build the fiberglass op slightly higher than the surface but not too much to make finnishing a little easier. Finnish the last two layers with matt then when cured grind or sand back down flush with the surrounding surface. You can start out with 36 grit to knock down the heavy stuff untill it is just barely higher, then switch to 60 or 80 grit to finnish then fill and final sand with 80 or finer grit. "
    valley springs, ca
    looks like from climbing into boat. thats is a common weak area. make a custom brace from stringer to side and will help it. dont make it to rigid or it will crack another spot
    Senior Member Bottoms Up's Avatar
    Is it only on one side of the boat?
    Promo removed by admin plz contact pb for advertising.
    Sep 2008
    OC, CA
    From the look of your sketch the crack is all the way thru and you need to put some matt on the inside. The best way I found to lay on matt in a tough area like that is as follows: Rough up the area with rough grit sand paper. Get a roll of wax paper and lay a strip of matt 6" to 8" wide and 6" past the length of the crack at both ends on the wax paper and saturate with resin. Press the matt up into the cracked area then carefully peel off the wax paper. Then touch up with a matt roller or brush to make sure it is all laying down. Depending on the thickness of the matt your using, you may want to do a 3" wide strip over the crack first then the wider one after. This I found to be the easiest way to get into tough areas and least messy. Then do the outside as Its Johnny has described above.
    Jan 2010
    Australia, N.S.W.
    Quote Originally Posted by Bottoms Up View Post
    Hey Bottoms up. There is the exact crack in the same spot on both sides of the hull.
    Jan 2010
    Australia, N.S.W.
    Quote Originally Posted by cp562 View Post
    Yeah your correct CP. The crack proceeds all the way through the glass. Was thinking of opening up the crack to a decent size, perhaps 5mm, then glassing from the inside as you have mentioned (Thanks for the wax paper trick). After that I was thinking of filling the opened crack with fiberglass filler against the new glass on the inside... Filling slightly higher than the outside surface for sanding down. The glass that has cracked is quite thin at this point... Looks like only 2mm odd!
    Jun 2011
    Dallas Tx
    much luck.. Post some pic and detail when you do! Id like to see how it works out. Im worried ill end up with a high spot where i plan to fix mine..
    Sep 2008
    OC, CA
    [QUOTE=BAHNER79AUSTRALIA;1509763]Yeah your correct CP. The crack proceeds all the way through the glass. Was thinking of opening up the crack to a decent size, perhaps 5mm, then glassing from the inside as you have mentioned (Thanks for the wax paper trick). After that I was thinking of filling the opened crack with fiberglass filler against the new glass on the inside... Filling slightly higher than the outside surface for sanding down. The glass that has cracked is quite thin at this point... Looks like only 2mm odd![/QUOTE
    I think it might be better to lay in a thickness inside first, then you can use your DA to sand a V angle outside and then fill in with matt.
