Removing painted name from rear of hull
Results 1 to 10 of 10
    TPC
    TPC is offline
    You who rock I salute you TPC's Avatar
    Catalina Island
    Default Removing painted name from rear of hull
    Paint is starting to peel off the fiberglass after just 6 months.
    I'd like to remove the painted name without gel coat damage, and come back with vinyl lettering.
    It's located on a HUGE fiberglass rear hatch door.
    Is this a job I can do at home, or should I remove the hatch and take it to a glass shop in the So Cal area?
    What do I use?
    Thanks.
    Your direction, not your intention, leads to your destination
    Assuming it's on with one shot lettering paint, EZ Off oven cleaner removes it without damaging fiberglass, but you will want to keep the stuff off your hands, trailer and other stuff. Maybe whoever did the lettering would take care of it?
    TPC
    TPC is offline
    Catalina Island
    Thanks.
    It was that really old guy in Newport famed for his lettering that did the work.
    Seems he does it for everyone. Good work, but peeling and way too big of lettering.
    Just not happy with the way it turned out in addition to many other reasons.
    Thanks for the tip.
    West Mich
    Try Acetone once or fingernail polish with Acetone in it or maybe Goof off which seems to work well also .
    Mar 2010
    Clarksville, TN
    Easy off is the way to go just did my boat and no problem at all. Just make sure you wash it real good after your done and don't let it set on there to long
    WFLC The REAL #321 M/E Kentucky Drag Boat Association
    S&S
    S&S is offline
    Steve S&S's Avatar
    May 2011
    Granite Bay, Ca
    I used Meguiar's Heavy Duty Gel Coat Cleaner on the back of the Rogers. With a little elbow grease, it took the three stage, candy paint, on since '79, name off the back. Then followed it up with some Meguiar's Marine Wax. Came out looking great. I was a little hesitant to use oven cleaner on the gel coat.
    Amazon.com: Meguiar's Heavy Duty Oxidation Remover - 16 oz.: Automotive
    Aug 2010
    if theres no clearcoat over the lettering just spend some time wetsanding it off. then take some rubbing compound and polish to shine it back up.
    Quote Originally Posted by TPC View Post
    Thanks.
    Thanks for the tip.
    Sure Ross,, it's a tried and true way,, not some myth,, don't get the stuff on your body.
    Feb 2012
    OC, CA
    Quote Originally Posted by ka0tyk View Post
    X2 if its paint over gel coat. Just use some 1500 wet & dry with water. Then compound and polish.
    TPC
    TPC is offline
    Catalina Island
    Thanks for the tips.
