Trailer tire help
Page 1 of 2 12 LastLast
Results 1 to 14 of 19
Trailer tire help
    Default Trailer tire help
    I have an extreme trailer with 235/60/15 tires which I'm hearing are low profile and tough to find for a trailer. Anyone run into this problem with an extreme trailer or have any ideas? I'd rather not have to cut and raise the fenders just to fit a trailer tire.... I've also been told that the company (Carlisle) isn't even making the tire any longer. Forgot to mention that the existing fenders are set up for this size tire and don't have room to go to a different tire size????
    Newbury Park, Ca/Bullhead City Az
    Default Trailer vs car
    How heavy is the boat? You may be able to find standard car tires in that size, but many shops won't install car tires on a trailer due to liability issues... If you can get away with car tire's load range, just take the rims in and don't mention they're going on a trailer...
    Ray
    PS you might try that web site "tire mart" or something like that....For real trailer tires..
    LOUD BOATS SAVE LIVES
    3 OPEN flatbottom APBA seasons left.....Let's RACE
    HONK if you voted for obama........
    It's that button in the middle of the steering wheel........
    The boat is a 28 ft Howard Sport Deck. Not sure on the weight, but I'd assume 5000 lbs. it just sucks that they make a trailer that tires aren't even available.
    Ray
    Argumentative SOB! Forkin' Crazy's Avatar
    Mound, Louisiana
    You can't get a lot of the sizes that you "use ta could". You're going to have to change some stuff to be safe.... Fender clearance, etc... I don't think I would trust that much weight on car tires. Sorry bro...
    "An armed society is a polite society. Manners are good when one may have to back up his acts with his life"
    - - Robert A. Heinlein
    Member dirtmover's Avatar
    alta loma ca.
    i just put 6 tow masters on my competive trailer that hauls a 28 conquest.. these were the same tires that came with the trailer.. mine are f65-14 very good wear ran them for 8 years before buying new ones.. look at americas tire discount tires
    Sep 2011
    Maybe it's just me, but I do radial car tires on all my trailers for boats. I just make sure the load range of the tire is appropriate for the weight it will be carrying, and then some. For example, 3000 pound boat with 800 pound aluminum trailer, round up to 4000 pounds. 4000 pounds divided by 4 tires is a load capacity of 1000 per tire, most decent tires can sustain that weight with a 34# cold pressure. Trailer tires tend to have a stiffer sidewall, and run higher pressures resulting in more shock to the boat and components than a softer radial. Just my thought.
    Huntington Beach Havasu TCHB's Avatar
    Huntington Beach
    I was just talking to a tire guy about trailer tires. He said the trailer tires the same size had a higher load range per tire.
    14 inch tires were rated to carry 1500 more per tire.
    May 2012
    Inland Empire / Havasu
    Trailer tires have more ply side wall compare to a car tire. you may be able to find a good truck tire with a higher side wall rating.
    Default Bias ply
    Quote Originally Posted by speedy59 View Post
    Some specialty "trailer" tires are bias ply, rather than the more flexible, smoother riding, radial sidewalls... Any tire listed as a letter size, ie F60-15, or E78-14, etc is a bias ply sidewall and by their very nature, will have a higher load range rating than a similar sized radial.... The down side, as mentioned already, is a rougher/firmer ride...
    Ray
    Senior Member fed4life's Avatar
    Quote Originally Posted by bigjack1129 View Post
    Who told you that Carlisle isnt making them anymore? I have the same trailer with the same tires. I bought 6 brand new ones last year from Discount Tire here in San Diego and got the lifetime warranty with them. So far they have been great; made about 8 trips to Havasu/Parker(about 600 miles round trip) on them plus a bunch of local trips to the lake. When i went looking for new tires to fit the rims and have them be direct replacements for the originals that were on there(manuf. date of 2004)it seemed that Discount/Americas Tire was the only place that stocked them.
    Jul 2009
    Hi,
    I had the same tires, they are car tires not trailer tires and they do sitll make them. I have a 2005 25 howard bullet - got a flat going to Tahoe last summer - went to put on the spare ad it was a 14", where the rest were 15" (guess a 15" tire and wheel would not fit in the spare slot on the Ellis trailer). I found that my boat was delivered with the same tires you have, which turned out to be car tires, much cheaper than trailer tires and now as well suited to handling the load as a trailer tire. I have an Ellis trailer and this was their "upgraded tire and wheel package" (guess this was one of the ways Ellis cut corners and made money).
    I was on I-5 - so I put on the spare, looked odd being smaller but worked fine - called America's Tire in Stockton and on our way by stopped and they installed 4 new trailer tires. I wanted Goodyear Marathon, but they did not have - so I went with their premium trailer tire brand, which was cheaper. I had no clearence issues going with a similar size trailer tire (they are 225's versus what you have).
    I was in and out of America's tire in 45 minutes - no harm no foul - no more tire worries for 4-5 years with 4 new tires. I would go someplace like America's tire or Discount Tire, who are all over the place as if you have an issue they will be close by to deal with it. They take great care of you.
    I would get rid of the Carlise tires, they were never meant for your boat trailer and once they start to crack on the side you will have blowouts. My blowout fragged the fender and step behind the rear tire when the entire tread flew off and it also hit the side of the boat and put a few big dings in the gelcoat on the side of the boat, not to mention a major black streak.
    Cost to repair the fender was about the same as 4 tires - do yourself a favor and just get 4 real trailer tires and forget the issue and focus on having fun! You should have no clearence issue with regular trailer tires, that is what the trailer was designed for (assuming you have an ellis trailer, like I do).
    Good luck.
Name:	Boat Photos 271.jpg
ID:	167504   Click image for larger version.
Name:	Boat Photos 275.jpg
ID:	167505   Click image for larger version.
Name:	Boat Photos 269.jpg
  13. #12
    Default Trailer tires
    I was told by a tire shop in havasu that the tire will be discontinued soon. Prob BS but there was 5 available in all havasu at $180 each. FYI, I have an extreme trailer and ended up speaking with Carlisle and they covered my old tires and sent me 7 new ones no charge. They did give me a different size tire in case I have issue in the future.
    Thanks for the feedback
    Quote Originally Posted by Supercup View Post
    Hi,
    Good luck.
  14. #13
    The510
    May 2012
    Los Anegeles
    Old boat, but just did my Ellis trailer tires for my 25 bullet, and what do you know one wheel was also a 14
  15. #14
    Dec 2009
    I learned the hard way that it pays to buy tires from a national tire store. I only buy from Big-O tires. I had a blow out in Utah, found a Big-O and they pro rated and replaced the tire. Had two tires blow between Colorado and Havasu. Same deal with a Big-O store in eastern Az. They're everywhere!!!!! Also, I always go for the highest load rating I can find in a trailer tire. If I can get a 10 ply then I go for it.
