Best trailer axle grease...and alignment Q
Results 1 to 10 of 10
    Default Best trailer axle grease...and alignment Q
    Sorry if thats a dumb question. In my case neither axle has brakes. I have been using this blue crap that says marine from the place I bought the axle. Yesterday was the 4th trip to the lake on a new axle this year....got home after a short hourish drive to and back from the pond and both sides got hot enough to start tossing grease. Arent bearings best packed by hand with a moly base lube. The trailer has some under lying alignment issues I need to deal with....gonna take both axles out...buy new springs...and start from scratch....hoping to limp through summer with what I have. One other question.....when squaring axles up....isnt pretty much the only measurement that is relevant...from the center of the tongue...to the axle(s) and obviously that they(axles) are spaced equal distances apart. I cross measured the back half of my trailer with a friends help....looks as though my trailer is 3/8'' outta square to add insult to injury.
    273.36 Miles from Havasu
    Thumbs up
    This is what I use. It is very tough, resists water well, and has a very high melting temperature. Maybe a little overkill, but our bearings get a workout.
    Perhaps I'm gay...
    Quote Originally Posted by Havasu Hangin View Post
    Thanks...wont melt at any temp(according to the ad). That sounds promising. lol I will try some.
    Las Vegas, All Over..
    lucas red and sticky works great and is available anywhere
    Mobile 1 is the only way to go,
    when you measure for the axles go from the hitch, even if the frame is not square, you want it pulling straight down the road
    #55
    Apache Lake Monger AZKC's Avatar
    Tucson
    Make sure your adjusting your bearing correctly. Here's Dexters recommended procedure. I know I was doing it wrong for 30 years. Its starts on page 8 of this PDF.
    http://dexteraxle.com/i/u/6149609/f/...rings_1-12.pdf
    Yep finger tight.....
    Thanks Paul. When I said tongue earlier....thats what I meant.....like where the center of where the ball on the hitch hits the tongue.
    Thanks for the help and links fellas.
    ytosemitesam
    Default Sooooo
    I don't read where you have had the trailer axles aligned, we have went through this even back on Hot Boat days, not just the distance of the axles from the [ball] tongue point, but that all four spindles aim the wheels straight forward in "alignment", you can wear out tires in a short distance if this is not correct, overheat bearing and all sorts of crap. a good alignment shop knows the procedure. hope this helps ?
    Senior Member HPBoats83's Avatar
    Corona, CA
    I run the Mobil 1 and am pretty happy with it, im getting ready to replace all my bearings and leaf springs.
    Sent from my DROIDX using Tapatalk 2
    Mohave Valley/Quartzsite
    Quote Originally Posted by Showrigger View Post
    x 2.. This is what I use.. If not Lucas Red then I use Mobil 1.
    Special Thanks to:
    Nelson Speed & Marine
    www.aholeregistry.com
    J.J. @ Beaver Fab
    Performance Boat Candy
