Concrete Guys - How Much for a Pad?
Results 1 to 14 of 27
    C-2
    C-2 is offline
    Senior Member C-2's Avatar
    Default Concrete Guys - How Much for a Pad?
    Hey guys, a little help here.
    How much would it be for a 40'X60' concrete pad for a steel building (the DIY type buildings).
    Any rough ideas?
    "The only two things in life that make it worth living; Guitars tuned good and firm-feeling women."
    Waylon
    Nine pieces of Eight OCMerrill's Avatar
    Mission Viejo, CA
    Your going to need a footing as well as a pad depending on the building you choose.
    Laveycraft 20.8 Sebring, Jeep Rubicon Unlimited, and no cash left.
    QE 60 - Trophy Girl
    I just recently priced some concrete out here for a pad for my shop. Not sure how much different concrete prices are on the west coast, but I can tell you what I found out.
    A yard of concrete covers 80 square feet at 3 inches deep. Concrete prices here ranged from $90 to $110 per yard, some with other fees added on. A 40x60 pad is 2400 square feet, so you would need around 30 yards of concrete (about $2700 - $3300) not including footings and labor for any grading or finish work.
    Monolith foundation work here is between 3.75-4.25 a square foot. That includes set up, and material. That does not include any additional fill that may be needed or the use of a pumper. Thats for 2400psi crete.
    Quote Originally Posted by Gump1986 View Post
    Standard slabs are 4" thick.
    Slow Learner CornWater's Avatar
    Quote Originally Posted by redneckcharlie View Post
    Probably a typo.. You can cover 81 s.f. at 4" thick.
    Quote Originally Posted by CornWater View Post
    I didn't look at his yardage figures, just noticed he put down 3", your probably right.
    Nordic 35' Flame Chico&Zeus's Avatar
    Anthem, AZ
    Depending on what the building is used for, slab might need to be 6" thick. Also turndown footing along sides might be required for structural support of the columns. Find out what the building manufacture requires or have it engineered. Also check local codes as they might require more than the building manufacture.
    R.I.P. Chico & Zeus I miss you both.
    Mission Viejo, CA
    Quote Originally Posted by Chico&Zeus View Post
    Permitted or not lags need to be in a footing or the first big wind and the buildings gone.
    Senior Member SConA's Avatar
    San Dimas
    What area are you in? Here in So Cal the new codes require 2' deep min footing without soils report. That would put you at about 42 yards. I would say 15 to 20 grand(no grading). I hear that concrete in the IE is going for as low as $85 per yard.
    LHC Architect SummitKarl's Avatar
    Havasu
    Quote Originally Posted by C-2 View Post
    Any rough ideas?
    4" slab with 1' footings, rebar and hold downs
    $10k give or take a couple hundy would be the cost in Havasu
  13. #12
    Senior Member haysonj's Avatar
    Santa Maria, Ca.
    The slab and footings we are doing for the wineries go for around $7.00 a sq foot. Probably a little more than what you need due to the forklift traffic.
    70 MPH Wakeboat Supercharged 383
    69 Chevy 4x4 383 Power
  14. #13
    C-2
    C-2 is offline
    Quote Originally Posted by OCMerrill View Post
    Permitted or not.
    Whachu talkin about Willis?
    Thanks for all the responses guys. Looks lik ethe horsies will have to stick it out old western style - no concrete (only the footing).
    Waylon
  15. #14
    Santa Maria, Ca.
    Any rough ideas?
    The building manufacture is going to tell you he will not warranties his building unless you have an engineer design the footings and I would go no less than 6 in slab if you are planing on vehicles being on it. $6.00 to $7.00 a sq ft would be close if done right.
