GM fuel gauge prob... Gauge cluster or sending unit?
Page 1 of 3 123 LastLast
Results 1 to 14 of 32
    Senior Member frdvschvy's Avatar
    Default GM fuel gauge prob... Gauge cluster or sending unit?
    The fuel gauge on my 2004 GMC Yukon did a strange thing yesterday. It pinned the fuel gauge showing way over full. At first I was thinking the sending unit has gone bad, but when the car is turned off the gauge only drops to half instead of all the way down. Because the gauge drops to half when the car is turned off and not all the way down I am beginning to think it may be a problem with the gauge cluster. There was a know issue and a Technical Service Bulliten for defective gauge clusters in 2004 GM trucks.
    What do you think? Gauge cluster problem or sending unit going bad?
    Kevlar/Carbon Sport Laminate Nordic 27 Lightning
    Quote Originally Posted by frdvschvy View Post
    cluster...
    Senior Member VegasRiverJunkie's Avatar
    La$ Vega$
    Had the same problem with mine. I know there is a recall and should be under warranty.
    Senior Member Mr. C's Avatar
    castaic, Ca.
    Is that the only gauge acting up. My wifes '03 started with the fuel gauge then went on to the MPH, Tach.
    sounds like the cluster, I think if you have under 70k miles they will replace it, not positive though.
    Take me to the river, drop me in the water
    Quote Originally Posted by Mr. C View Post
    special policy 07187 it is covered to 70K miles...between 70 and 80K GM will pay for the part, not the labor
    Same thing happened on my Avalanche, temp guage, fuel guage, then spedo.
    castaic, Ca.
    Quote Originally Posted by x7734x View Post
    Next you might start getting the noise from the steering column under the dash (forget the name of the peice).
    They don't make the part for my wifes car anymore so every other oil change it gets lubed up.
    intermediate steering shaft
    Dan <-----just here to help
    castaic, Ca.
    Quote Originally Posted by dicudmore View Post
    and a fine job your doing
    ..... rivergames's Avatar
    Los Angeles / Parker
    The only problem with chevy's are the clusters
    Life is too short for a slow boat
    Quote Originally Posted by Tor View Post
    Balls drop, balls grow, and balls eventually get placed into a woman's purse. That's usually when the hard passes in front of Fox's stop and the busting of youth's balls start
    Senior Member Cdog's Avatar
    Scottsdale
    Quote Originally Posted by rivergames View Post
    My power steering hose is leaking. Other than that no problems so far...
  13. #12
    yep, they'll cover up to 80k on the part, you pay labor. did 2 today
  14. #13
    Yep, replaced the intermediate shaft about 6 months ago
  15. #14
    Thought I was on the right track with the cluster. Made arrangments to drop it off at the dealer and have it taken care of. I am over 70K so it looks like I will be paying for the labor. Will GM replace the part and let me do the work myself or would they require I pay the high dealer labor rate?
