496 Mag Issue
Looking for some opinions on what might be wrong with the 496 Mag in our boat.
On our very last trip out last season the engine developed an issue where it would start but have limited power when it was cold. Once it reached normal operating temp (160) it would run fine. The engine almost behaved like it was flooded. Even with full throttle it didn't have enough power to even get on plane, until it came up to operating temp.
So I had it in for service over the winter. The repair shop checked the plugs, alternator voltage, and replaced the fuel filter. No codes were set or pending. According to them it ran fine on the hose. About a month later we attempted to use the boat and once again it did the exact same thing, except this time the problem did not go away after the engine came up to normal operating temp. I could smell strong gas fumes and the boat barely made it back to the trailer. This issue has definitely gotten worse.
Any suggestions?
http://www.performanceboats.com//showthread.php?t=37171
Thanks.
LinkBack URL
About LinkBacks
JK. I have no clue just thought I'd throw that out. Kinda weird that no codes are popping up. Good Luck!!
