Get a Webber charcoal grill...![]()
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties......... Honest Abe..........
Seems the new ones go down to "low flow" every once in a while. Turn off gas and disconnect BBQ and hook back up, thats worked for me....best solution I found is to switch to gas and don't worry about it any more![]()
Regulators mount up......
oh wrong regulator!
Just switch it to natural gas, and hook it to the house. It really simplifies things.
9 times out of 10 its NOT the Reg... its your OPD tank... nasty little check ball in the valve.. Go to a PROPANE shop.. they will set you straight.... regs hardly go bad.
Regulaters don't work when the tank is Empty
