2004 h.d. 3/4 ton with the duramax. i blew my rear diff. seal at the front of the housing. how hard is it to replace? filled up the fluid and it is just pouring out the front![]()
slot
87 eliminator
76 cole tr1-1/2
next boat crazy
new owner of the redneck yacht club
stockton, ca.
gravy, just need a harmonic balancer puller to press off the pinion yoke.you can just use the ujoint strap bolts. check the seal on the back of it too, sometimes they melt and ya have to buy a new yoke![]()
s480@18lbs nto 325cubes of whoopass : ) turbo boyz
do you know what part #'s i need? the dealer out here is not the smartest![]()
slot
87 eliminator
76 cole tr1-1/2
next boat crazy
stockton, ca.
Make sure you put teflon sealer on the pinion spline, I have seen them leak down the splines and also clean the vent and hose !!!
/ The Few The Proud TheBlown
so i just got around to trying to do this. what socket do you use for the big a$$ nut that holds the balancer on?
slot
87 eliminator
76 cole tr1-1/2
next boat crazy
stockton, ca.
yeah, take the big nut off and there's a washer behind it, a magnet will pull it out. use a harmonic balancer puller across the 2 ubolt clamp mounts and press against the pinion, the yoke will pop right off. only tighten the nut till it stops, don't keep hammering it with a impact gun or you'll crush the sleeve more and jack up clearences![]()
ok back at it. got the driveline out of the way, now its timew for the big ass nut. what size socket do i need? if i have to buy one i want to make sure its the right size.
slot
87 eliminator
76 cole tr1-1/2
next boat crazy
stockton, ca.
i think its a 1 1/4 , been awhile
