Looking for Jeep mechanic in Havasu
Page 1 of 2 12 LastLast
Results 1 to 14 of 18
    Senior Member Bohica's Avatar
    Default Looking for Jeep mechanic in Havasu
    I have a 2000 Jeep Wrangler with the 4.0. I'm having an oil pressure issue that's making me a little nervous. Oil pressure at start up is around 40 psi. After warm up, it drops to 20. After an extended drive, it will drop to 0 at idle and the check guages light comes on. Rev the motor or get going again and it goes back up. Seeing the oil pressure at 0 was freaking me out a bit. Don't ever want to come back on a tow rope, so looking for the go to guy in Havasu.
    Thanks for any help.
    Senior Member LHC30's Avatar
    Upland, LHC
    did you try Darryl (Shadow here on the boards) at Robinson Automotive???
    Above The Wet Spot Sigus's Avatar
    Scottsdale / Havasu
    Robinson Auto takes care of mine.
    What did you use for the last oil change?
    I use Havasu Auto Care. They have always been up front and honest and have done a great job for me. They back up their work 100%.They not only take care of the work you have a problem with but also do a complete inspection. Plus when the work is done they detail your auto.
    928-505-4470
    call Darrell @ Robinson Automotive 928.486.7399
    Member In Training Shock 'N' Awe's Avatar
    Quote Originally Posted by IExcel View Post
    x12
    Senior Member Chuck Wagon's Avatar
    Palm Desert
    Quote Originally Posted by Bohica View Post
    Call Hesco 205 251 1472 ask for Benny tell him your problem he will steer you right, And tell you what to check they built my 4.7 motor good guys
    Senior Member chevy's Avatar
    havasu
    Put 50wt. oil in it
    Senior Member Roaddogg 4040's Avatar
    Lake Havasu City, AZ/Algonac, MI
    I used Mike Lock... 928-412-0021 He installed the lift kit on my Rubi. Good mechanic...
    Steve
    In a house, on a street, in a city, in Arizona.
    x47.
    Senior Member milkmoney's Avatar
    vegas
    Quote Originally Posted by jordy View Post
    x47.
    x94
  13. #12
    Senior Member Redneck's Avatar
    Lake Havasu
    Hit up Robinson Automotive Shawdow on the boards he is the best in town
  14. #13
    Senior Member shadow's Avatar
    Lake Havasu
    Thanks for the kind words everyone!
    Bohica i'd be glad to do a manual oil pressure test for you & verify that the gauge is working properly and get to the bottom of your oil pressure concern.
    Darrell
  15. #14
    "BOUGHT NOT BUILT" 2FORCEFULL's Avatar
    damn... is this the jeep you just got??
    you stay'n the weekend?
    shadow will take good care of you...
