Cruising speed / Top speed
    Senior Member Wishful Thinking!'s Avatar
    Apr 2009
    Irmo S.C.
    Default Cruising speed / Top speed
    When looking at boat ads... how do they come up with cruising speeds? I was looking at an ad for a 44' Baja with three 500 hp... listed cruising speed at 50. How would that relate to top speed?
    First boat - 1968 Starcraft 14' 40hp
    Second boat - 1982 15.5' Glastron 115hp
    Current boat #1 1987 Ski Nautique 230 hp
    Currnet boat #2 - 2005 Magic DB 425 hp
    New here Beer:30's Avatar
    Bakersfield, CA
    Quote Originally Posted by Wishful Thinking! View Post
    Cruising is "typically" at 4000 rpm. Low cruise is 3000, normal cruise is 4000. 10mph per 1000rpm is probably "average" efficiency in cruise. It technically has nothing to do with top speed. Everything changes in most boats when you pin the stick(s). Less wetted area, etc. Stepped hull? That makes a big difference in BOTH cruise AND top speed.
    V-bottom vs. Cats is also an apples-oranges deal. Cats generally will start packing air during cruise, making them more efficient.
    BTW, I also answered your question in the 600/700SCI upgrade thread.
    Originally Posted by gn7 Its amazing any of us can even get back to shore each outing with those old tech POS we use.
    [IMG]MVC-039F.jpg[/IMG]
    Ultra 26 Shadow
    Mission Viejo
    I always thought cruising speed was 3/4 throttle
    Orlando.FL
    Get the boat up and running fast then slowly back down until the boat wants to sink down. Each boat is different because ,power,hull design, and the amount of weight from passengers, etc.
