Electrical help
Results 1 to 14 of 14
Electrical help
    Senior Member Game Time's Avatar
    Corona, Ca
    Default Electrical help
    I'm switching out a traditional switch that controls a motion light with a switch/outlet combo. I have power to the outlet part but my switch is not working. What am I doing wrong?
    New switch/outlet...
    White wires connected on same side...
    Black wires connected on same side and ground wires grounded.
    Inside of the box...
    Morgan Hill
    You need the "Black" to go to the "Black" for the lamp to work, it looks to me like you have a neutral "white" wire trying to power the light, no good...
    Sometimes the wires get run funny to save time, make sure there is a neutral and a hot, the two white wires should be tied together, the black wires should be one for the outlet and one to the lamps (like the top white wire should be the black lamp wire...
    Hell I even confused myself this time....Do you have the cut sheet to the new switch?
    edit: I guess in other words, the light power black wire should go on the brass screw...with the two neutrals together....
    GT
    Arroyo Grande
    pm me your number I'll walk you thru it
    Team CJ460 Just Electric's Avatar
    granada hills
    find the hot /pig tail it and the same for the neuts and then use the spare wire which should be your switch leg/lite and put that on the switch side
    slalom skiing=best drug 74glencoe's Avatar
    Alamogordo NM
    Default brass is the key
    1. take all your wires off except the ground
    2. find out which black is the actual hot with a milti-meter or "hot-pen"
    3. make the two whites and a 6'' piece of white together with a wire nut.
    4. take the other end of the 6'' white to the silver screw.
    5. take the black that is not hot to the brass (gold) colored screw
    6. take the hot to BOTH black screws
    7. screw it all back into the box, put the plate on, crack open a cold one.
    Life is all about ass, you're either covering it, hauling it, laughing it off, kicking it, kissing it, busting it, trying to get a piece of it, or behaving like one.
    originally posted by ritcheyrch
    Tim
    Tim is offline
    Senior Member Tim's Avatar
    Hangtown, Ca
    The gold screw is where the line side "hot" of power will need to be connected. Both whites should be connected to the silver screw. The two black screws are switched. 1 is for switching the outlet of the device and the other is for switching a light or fan. To find out which black is power just hold the ground lightly with one hand and lightly touch the black with the other and you should get a light tingle, the tighter you hold the more tingle you get. Another thing to remember in AC power is the black red blue wires are hot and they go to the gold screw. Like colored people have gold teeth.
    Happy Member
    Under a Rock near ???
    Quote Originally Posted by Tim View Post
    What in world are you talking about ????Hold the wires and get a lite tingle??????? Maybe you should stand in a bucket of water with your shoes off and stick YOUR hand in to the buss bars of your main panel !!!! And please report back to us about the tingle !!!!
    Tim
    Tim is offline
    Hangtown, Ca
    Only kidding. But it will only give you a little buzz if held very lightly.
    granada hills
    Quote Originally Posted by WishIknew View Post
    now thats where the term electricians do it without shorts
    Happy Member
    Quote Originally Posted by 74glencoe View Post
    He also needs to pigtail the grounds not leave 2 wires under the screw
    RvRrat
    Guest
    If you don't have a meter, here's a quick way.
    Remove both whites and pig tail them with a small piece of white wire & wire nut, run that to the silver.
    Move one of the blacks to the gold.
    Jumper the blacks together with a small piece of wire.
    If the recepticle doesn't work, switch the black wires around.
  13. #12
    Senior Member jetboatrich's Avatar
    Sep 2008
    Saint Charles, Illinois, United States
    Is it fixed or did you get shocked, drank a beer and gave up
  14. #13
    Corona, Ca
    Quote Originally Posted by jetboatrich View Post
    I grabbed the hot wire real tight!!! Just kidding. It's up and running now. Thanks for everyone's help.
  15. #14
    Dreaming of snow catman-do's Avatar
    Rancho Cucamonga
    When doing electrical I like to think of it like a big battery. I know the ground has no insulation, and to figure out which one is hot, I use the old battery to the tongue trick. Hurts like hell the first time, but you get used to it after a while. Better than taking 5 hour energy!
