Anyone have one? Gas or Electric?
House has city water and electric, but runs off of propane should I stay with electric or maybe switch to a gas one?
I have a pair of high volume ones I purchased for a home I never built. After researching quite a bit, I found this was the best way to go. Mine are for propane.
Heat your electric tank during non-peak hours and you will come out way ahead with fewer headaches.
1984 26' Sleekcraft Ambassador
Chevy 502 Bravo One Drive
1978 56' Carlcraft Houseboat
Twin Chevy 454's V-drives
Thanks!
What is the smallest size Water Softener that is available?
I'm sure you can find someone in the yellow pages or someone here can give you a referral. You can always pick one up at Home Depot,Sears or Lowes but those are low end units.
You must prepare for the darkness while traveling in the sunlight!
Thanks for all the info definitely will be researching more about these, and about water softeners.
