Originally Posted by
Mrhavasu
So I do the annual oil change in the drive and I figure that this time after pumping the oil to the vent hole, I will plug the vent and keep pumping oil to the bottle in the transom, instead of filling from the top of the bottle down. After screwing the vent plug back in and pumping oil from the bottom up, it began to be hard to move the oil. I had removed the cap from the reservoir bottle to allow air to escape. The hose connected to the little oil bottle pump now kept popping off, but I was able to hold it on and fill the unit up. Next day I see the leak. Appears to be the drain plug behind/below the prop. ( Thats where it is on the xr drive.) I replace the gasket on the drain plug, no big deal. Still leaks. Obviously not the drain plug. Did I damage a seal or o-ring? I do not know what to think, Thanks
