Originally Posted by
C-2
I run old computers too and unless the motherboard goes, I plan on keeping these dinosaurs.
Always remember.....ike an engine, routine maintenance on a computer is necessary. But even with maintenance, sometimes a computer gets bogged down with so many different or changed settings, that starting with a fresh reformat is the best way to go. You can try to clean it up first, though.
Personally I use Iolo Syetem Mechanic. I've used this program for about 10 years now. It runs on autopilot and does all the maintenance stuff automatically every night when I'm aslepp. It also comes with Kaspersky Anti-virus, and truly is one of the 3-4 core programs I could not live without.
What is Iolo System Mechanic?
For free, start by blowing out your system. Disconnect the power supply and blow the crap out of it. Yes, some of the geeks will come on here and tell you not to do it that way due to condensation in the compressor air...whatever. Just run the air for a minute or so and then give it a good blast. The cans don't work worth a shiat, BTW.
Is there a certain psi you use?
Run a defrag of your sytem. If it hangs and will not finish a defrag, then try Ultimate Defragger, they have a free version.
CCleaner is a great, free cleaning application. It will clean out some stuff and fix your registry.
Where do you get CCleaner?
Find an antivirus application and run it. Microsift Security Essentials is always up to date and is trusted. Run it with Malwarebytes too. Scan only your system files, otherwise the scans can take forever. DO NOT RUN several different antivirus applications at the same time, Stick to one, and Malwarebytes seems to play nice with many othe rflavors. So use one Antivirus and Malwarebytes.
I run Avast
If you are removing programs, Revo unisntaller is the way to go. They have a free version, it's all you need. Many times the resident uninstall features of the program you are removing will remove almost everything. Almost. Some programs like to keep registry entries and other bits and pices of their stuff on your computer. Revo uninstalkler finds those bits and pices and removes them too. Follow the instructions closely - mainly, only delete the items in bold when delting the registry entries.
Export your favorite bookmark so you have a backup copy of them. CCleaner should clean out your cookies, but also clean out your adobe flash cookies. Do a google search under "adobe flash cookies" and it will take you to the Adobe site where you can delete them.
How do you export your bookmarks?
Without knowing if your computer is up to date, it's hard to say if you need to download any updates. If anythiung, try to keep the Adobe Flash Player and any other Adobe flash stuff up to date.
The only update it says I need is system 3 update
The reason I use Iolo System Mechanic - it does all the above, except the compressor part.
And BTW, your chances for getting your credit card info jacked are far greater offline, than online. The majority of all credit card/atm fraud originates from gas stations, atm's and crooked ass employees. In fact, if you use your atm card regulary, it's just a matter of time before your account will get hit.
