I have the Pro Mariner 12, 6 amps x 2 banks. Two batteries (stereo) on one bank and starter battery on other. All three are Optima BlueTops. Going on SIXTH season now.
What I have learned is - you only need the MINIMUM charging amperage per bank. If there is a ONE-amp per bank model - that's fine. Here's the reason:
You run your stereo all day at the lake, draining that "side" of your batteries. You start up and run across the lake a few times in between - thus charging (mostly, if not completely) those batteries again. At most, you run the stereo some more and then ultimately, you drive the boat back to the launch ramp. You idle around there for awhile and then put it on the trailer. So, all of your batteries are mostly - if not completely - recharged.
Now you park the boat. They are already mostly charged, so they don't need much at all. Even if they are only 50% charged, a 2-amp charger would easily top them off overnight. I don't know about you, but I have NEVER come off of the lake with dead batteries.
So, you need a "maintainer" more than you need a charger. Pick whichever brand/model you want - just don't spend money for a lot of amperage. The high amperage is for bass boats that come off of the water with dead trolling-motor batts.
Marine Battery Chargers | ChargingChargers.com
