Mike,
Is there an alternative to using a Zerk fitting to pump grease into the bearing on a Jet Pump? It is a P.I.T.A. getting under the hatch with a grease gun trying to reach that little sucker.
Thanks,
BMac
Mike,
Thanks,
BMac
You could always add a hose and relocate it to a better spot on the back of the engine using a little bracket. We'd do it all the time with heavy equipment and put all the zerks in one place.![]()
Yes. Initially setting it up might be a pain, but it would be a one time pain. You'd have to figure out the thread size for the zerk, which shouldn't be hard, and then they make different hose lengths with threaded fittings on both ends. Thread one end into the pump, run the other one up and mount it wherever you want it and you're home free.
Can't imagine that you're the first one to run into this kind of problem.
BM the ideas above are good ones. Different pumps have some different locations for the zerk and yeah some can be tough to get at. I've done remote grease fitting on many boats in the past either with just a hose and zerk in the end or an actual mounted little custom block with passages to multiple zerks (which you don't need).
Rex Marine Home
Rex Marine Shopping
Mike
909-592-1000
See my photo gallery at mikegeephotos.com
A tribute to the victims of 911 - Never Forget!A Tribute to our Troops (Remember Me)
Please Spay & Neuter your Pets (a video)Please adopt and learn about the huge problem of overpopulation (a video)
Please Feed a Shelter Dog (It's Free) - Your clicks can mean the difference between life and death.<<<![]()
“He who is cruel to animals becomes hard also in his dealings with men. We can judge the heart of a man by his treatment of animals.” Immanuel Kant
