Ski Tow
Results 1 to 7 of 7
Ski Tow
    Strap on the JATO konajet74's Avatar
    Antioch,Ca
    Default Ski Tow
    Rex, are there different Ski tows for a BBC jet? Your website
    shows a pic of a short & tall one and no option to choose?
    Thanks!
    Just an ordinary non wall street fat-cat non Washington insider American in San Dimas, CA
    Blog Entries
    24
    Quote Originally Posted by konajet74 View Post
    Thanks!
    The vdrive model is the shorter one (mounts on front of engine).
    The jet model is the tall one (mounts on rear of engine).
    Which are you looking for?
    I have a few in stock.
    We recently aquired all the tooling and fixtures, materials etc. from L&L Marine when the went out of business. Our plan is to continue manufacturing them on a limited basis as market requires.
    Antioch,Ca
    Rex, I need one for a BBC Jet in SS, if you have it. I also
    need a jet driveshaft guard, a Banderlog Valve w/ HEI
    converter & a Autometer PN#220764-33 w/ sending unit
    pn# 990344. Would you happen to have all this in stock?
    Blog Entries
    24
    Thumbs up
    Sent you a PM. ... Thanks
    Charlotte, NC.
    Rex,
    I got one it has just seen better days on the finish.. If your making these you would not possibly be able to refinish one? if so how much?
    Blog Entries
    24
    Rex,
    The problem is re-chroming these is the polishing process. It can be done but the part first has to be stripped, then repolished, which assembled is next to impossible if there are any pits, then rechromed. It may not end up much cheaper than buying a new one... I would have to see close up pics or see first hand to tell you....
    Mike
    Charlotte, NC.
    PM sent.
