Thru hull fittings
Results 1 to 5 of 5
Thru hull fittings
    Senior Member grayson's Avatar
    Australia
    Default Thru hull fittings
    Hi, i have your water inlet fittings in my Transom (Part number 483104)
    http://shopping.rexmar.com/Merchant2...tingsbulkheads
    I'm wondering if the 10 AN fittings with a hose barb ( i am using rubber hose)
    will screw onto the thread inside the boat?
    The Fitting i have in mind is a Straight hose end with hsoe bard-
    Like this -Part number 404-10
    http://www.speedflow.com.au/hoseends.html
    I'll need to buy the stainless fittings again as i have currently modified( read destroyed) my existing ones to adapt a hose barb to them to get it useable. If you have screw on fittings i'll get them through you otherwsie i'll just buy the thru hull fittings and get the AN fittings locally- assuming they will work together.
    Thanks for your time
    Grayson
    Just an ordinary non wall street fat-cat non Washington insider American in San Dimas, CA
    Blog Entries
    24
    Quote Originally Posted by grayson View Post
    Grayson
    Grayson, yes they should work and we can supply you with similar hose-barb fittings.
    Just let me know if you have more questions. Mike
    Australia
    thats great thanks Mike,
    i guess now i'd like the part number for the hose barb fitting - i could not find it in your site, was it an XRP fitting?
    soon as i know it i'll order thanks
    Grayson
    Blog Entries
    24
    Grayson
    Here is a link http://www.rexmar.com/page177.html
    Just replace the KB (former name) with XRP.
    Mike
    Australia
    Mike
    Thanks Mike, once again, outstanding service
    all the best
    Grayson
