Oil pres. sender
Results 1 to 5 of 5
Oil pres. sender
    Placentia, CA
    Default Oil pres. sender
    Need an oil pres. sending unit for a 0-100 lbs. Gaffrig gauge. Anything special?
    steveo143 AKA DiMarco 21 II
    RIP Davey B and Denis
    Just an ordinary non wall street fat-cat non Washington insider American in San Dimas, CA
    Blog Entries
    24
    Depends on if the gauge is calibrated for Merc or otherwise. What sender are you replacing? or, do you have a part number on the particular gauge... Newer Gaffrig...older Gaffrig built by Livorsi... etc.
    Placentia, CA
    The gauges were purchased in June of 2006. Part #55122 for the oil pressure gauge. Sender part #9106. Bought this boat, the green metalflake Schiada about 6 weeks ago and the sending unit was not there, just had a mechcanical on it. The in dash Gaffrig saved the motor from a meltdown as the previous owner saw a lack of pressure and shut down. Broken oil pickup, but no motor damage.
    Blog Entries
    24
    Steveo I'm going to send you a pm on this
    Placentia, CA
    Thanks Mike for your trouble. After going to there website it appears that I have one on a motor that I recently bought to go into the old Campbell woodie flat that I have. Iwill try it since the Campbell is set up for a mechanical gauge. Thanks again.
