Bad ASSS Wheels n Deals
Page 1 of 2 12 LastLast
Results 1 to 14 of 16
    Just an ordinary non wall street fat-cat non Washington insider American in San Dimas, CA
    Blog Entries
    24
    Default Bad ASSS Wheels n Deals
    Ok I got some excess inventory I want to move out. That's what this thread is all about. Quantities are limited to stock on hand.
    Here we go....
    pm me to receive these deals, first come first serve on all.
    Blog Entries
    24
    I have some categories and part numbers of Vicious Billet speaker grills I am heavily discounting. These are stock reductions or discontinuations and these prices won?t be repeated. When they are gone they are gone.
    There are no colors offered in this group of product, polished only.
    Quantities are approximate and are subject to actual quantity on hand. No rain checks, no special orders, no considerations if we do not have quantities listed.
    8", 10", and 12" round have external mounting tabs
    6.5" round and 6" x 9" have backplates that mount behind the speaker.
    Again this list is ?all I have? that are discounted. We do have other stock in some styles and sizes.
    Ok here is the list:
    Blanks ? These are uncut grills, polished. They are solid, no pattern has been cut. User can mill or water jet their own pattern or logo. Dealers or OE?s this would be a good opportunity to save some money.
    8" Round - $29.00 each
    10" Round - $29.00 each
    12" Round - $29.00 each
    Flames design:
    Girls design:
    6.5" Round - $89.99 pair
    Spinner design:
    Tribal design:
    Snap em up they are DIRT CHEAP. This sale won't be repeated. When new grills are brought in for 2012 they will be much higher in price. These are first come first serve and the listed quantities are only what we had when posted. Sale prices are subject to quantity on hand at time of order.
    Blog Entries
    24
    Default Heat Exchangers, Oil Coolers
    3" diameter and around 23" long. All are new. They are also 100% Cu/Ni (cupronickel) construction, have both drain and pencil zincs installed. This is a two-pass design set up for 1/2" NPT fittings for both oil and water. Three of these were installed but never used, the balance are still setting in the OEM boxes. These were built by SeaKamp of Seattle. About 20 are available at post time.
    Price is very reasonable at $195 each. - one left
    Blog Entries
    24
    Default Dooley Oil Pans Cheap Cheap
    These are brand new oil pans. All for sale at cost. Snap em up. One of each only. Pans include pickups, windage trays where applicable.
    Rex # 182140, Dooley # 011000, 14 quart Offshore Mark 4 BB Chevy,
    Regular Price is $673.99, Sale price is $450.00 (this one's below cost)
    Quantity 2 of this pickup
    Rex # 182191, Dooley # 013013, Ford 460 Jet Pickup (slip-in)
    Regular Price is $111.60 ea, Sale price is $50 each (this is below cost)
    Blog Entries
    24
    One pair of Header Braces for Bassett Twistie headers on BBC Jet or Vdrive
    Braces come undrilled as headers vary in position. Small spacers may be required. Bolts and spacers are not supplied.
    Part # 128144
    Regular Price is $150.99
    Sale Price is $90.00
    Blog Entries
    24
    Default Underwater Halogen Lights, 2 available on sale
    Marine Hardware Underwater Light Water Jacketed Assy, Stainless, Halogen 50W - These are the real deal, they are bright.
    Designed for Fiberglass or Metal Hulls
    Cast 316 Stainless steel body, nut, and polished lens cap ring
    2 1/4" x 6.5mm thick borosilicate glass
    50 Watt Halogen, 1100 Lumens
    3 1/8" OD on body
    4 3/4" Overall Length
    3 1/2" Threaded Length
    5 pounds
    Part number SSUL 21000, code 456800
    These lights are engineered for safety with water jacket thermal dissipation and an internal over-temperature shutoff switch to ensure that neither the light nor surrounding objects will ever overheat. The light is manufactured out of 316 stainless steel, with a brightly polished exterior ring. The assembly installs in the same manner as a regular thru hull fitting. Design features include wrench flats on the lens cap for easy tightening and a cast-in grounding lug on the body.
    Normal Price on this light is $299
    Price reduced to $150 ea. 2 only, no rainchecks.
    All sales are final on inventory sale items. Tax (to CA destinations) and shipping (actual shipping charges via UPS) will be added to all orders. Orders to outside of CA do not have sales tax added.
    Blog Entries
    24
    Default Custom Marine Clamp-On Silencers 4"
    This is a pair of NEW Custom Marine Inc (CMI) Clamp-on Silencers with Flappers 4" Stainless Steel
    These Silencers clamp directly onto existing straight end 4" exhaust tips
    Normal Price on this set of silencers is $600
    Sale price on these is $225 off = $375.00. One set only, no rainchecks.
    Blog Entries
    24
    This is a brand NEW Merc Mechanical Trim indicator. Bottom cable type, 2 drives, 2 tabs.
    $260
    Blog Entries
    24
    Moon Timing Cover for 303-394 Olds Engine - This long since discontinued part is NEW and never installed on an engine. NEW and pristine condition. The water ports are not even drilled and tapped so user can do whatever size they want. Cam cover bolts on with 2 allen head bolts.
    $395
    Blog Entries
    24
    Gale Banks marine small intercooler housing, polished aluminum excellent used - This is a rare part long discontinued by Gale Banks. It is the housing only as pictured. Does not include intercooler core or end plate. This housing was used on the lower HP turbocharged marine engines by Gale Banks in the 1970's and 80's.
    $250
    Blog Entries
    24
    MSD 8560 Pro Billet "marine" Distributor.
    Just found a brand new one I didn't know I had, new in box, $295, Free freight to lower 48 states.
    Another MSD 8560, brand new off a display we're not using any longer. This one is minus cap and rotor (sold them I guess) but has a brand new set of MSD blue 8mm Solid Core Heli-Core Suppression wires for BBC.
    Same price on this one including the wires, just short cap and rotor... $295, Free freight to lower 48 states.
    And one more, this is a brand new display unit also but an 8562 with the slip collar for a tall block (or adjustable for std block), this one also has same wires as the one above for BBC. $345, Free freight to lower 48 states.
    If you want it without the wires then $295 like the others.
  13. #12
    Blog Entries
    24
    2" long Water Pump Extension for Neovane Marine Water Pump - $89.99
    4" long Water Pump Extension for Neovane Marine Water Pump - $99.99
  14. #13
    Blog Entries
    24
    Manley 25795-8 ..3/8" Pushrods for Big Block Chevy, NEW in Box
    4130 Swedged End for Big Block Chevy 3/8 x 8.280" long, .080 wall
    1 set of 8 only, $84.99. Summit is over $100
    Manley 25796-8 ..3/8" Pushrods for Big Block Chevy, NEW in Box
    4130 Swedged End for Big Block Chevy 3/8 x 9.250" long, .080 wall
  15. #14
    Blog Entries
    24
    Quote Originally Posted by hondoboat View Post
    Hey Mike, any chance of a drive shaft tube adapter at the flywheel cover end? And possibly flywheel cover for bbc?
    I do not think I have anything used in a tube adapter. I will look around though and quote you on a new one if not.
    On our flywheel covers, new ones are $161.99. I have some at polishing now I believe.
    I also have a group of flywheel covers that have more porosity than I care for. So I will sell them as seconds if you're interested. They are functionally fine, just more pits in the polish than I can live with for first line product. Price on these is $135 ea. They are not horrible by any stretch, just not smooth all over like I require. It is the Chevy Flywheel Cover, mid-page below
