Rex Marine is now distributing both B&B and Stef's Marine Oil Pans. The Stef's fabricated pans will be introduced a bit later.
The B&B 10 Quart Jet Drive Oil Pan is the finest pan for the money you can buy.
One piece formed pan body, not pan rails with a welded-on box
Body is heavy gauge steel made by the same company that makes stock GM pans, not a cheap imported thin gauge pan.
2 sets of directional trap doors to keep oil around the pickup
Directional windage screen , not a sheet metal tray, mounted in the pan keeps oil in the sump where it belongs, not on the crank where it robs horsepower and aerates the oil causing oil pressure problems and even engine failure
10 quart capacity, some would call this a 12 quart pan but it is called 10 quart by B&B-Stefs because that keeps the oil below the windage screen
Fully fabricated weld-in pickup. This pickup is a stout piece
Fasteners are included
All this at a price far less than lesser performing pans - $319.99
B&B Pan presently available for Mark 4 style BBC engine only
Pickup options available for all popular Melling Oil Pumps, specify oil pump being used when ordering pans.
We also will have the Melling pumps in stock shortly.
The first group of B&B Pans will be in stock around May 15th.
LinkBack URL
About LinkBacks
909-592-1000
