AFR Heads Blow-Out!
Results 1 to 2 of 2
AFR Heads Blow-Out!
    Platinum Advertiser Teague Custom Marine's Avatar
    Valencia, CA
    Default AFR Heads Blow-Out!
    TCM, has (4 sets) of AFR BBC, Aluminum, 315cc, fully CNC ported, w/ valve job, NO PARTS, 3/8" valve, ready for assembly. Retail's for $2818.00pr.
    http://www.airflowresearch.com/index.php?cPath=68_74
    TCM SALE $2397.97pr
    TEAGUE CUSTOM MARINE
    661.295.7000
    www.teaguecustommarine.com
    Valencia, CA
    Default How about this...
    How about we sell you the heads complete?
    AFR 315cc (Custom CNC, Aluminum castings) Manley severe duty valves, Comp springs, Manley retainers and locks, Crane Seals, ARP rocker studs, AFR guide plates, special shims, and assembled and ready to install... Or you tell us your motor, and you get a custom set specially designed for you!
    $4,050.00pr....?
    A few sets still available, so jump fast!
    661.295.7000
