1975 Chevy 4x4 Stepside 3/4 ton running gear 300+ hp 350 engine Custom Truck Project
Have a 1975 Chevy Shortbed stepside with 3/4 ton 4x4 running gear .. truck is Tittled as 1975 but is a 1983 cab and bed on my 1975 frame.. has tons of things done to it and needs a few things finished.. First off the Engine is a 350 4 bolt main that has about 10K miles on it and i tore it down and went with a Lunati Voodoo Series High lift RV cam and had the heads completely gone thru and set up for hi lift cam ... heads are a rare 1969-1971 casting and are suppose to be 2.02 heads.. also has the Air Gap NON RPM version intake .. all these parts have Zero Miles on them.. trans is a th700r4 with a NP 208 t-case.. has 78 chevy 3/4 ton axles in it with Warn Premium hubs .. dana 44 front and 14 bolt full floater rear.. also have a set of Stainless steel Headers for it .. wheels and tires are 35 Goodyear MTR's mounted on MotoMetal Black powder coated Alloy Wheels.. i have about 3500-4000 invested in the truck . will sell for 2300.00.. theres lots im leaving out.. truck does need to be finished. engine is bolted and mounted in place but no wiring is conected . drive shaft in front is missing and needs exhaust built for the headers .. all the hard work is done .. need to pay bills is why im selling. dont want to sell it since i was building it for myself .. Bill 530-333-1047 .. also parting truck out if it dont sell and i have something you need. let me know. btw has a 89-91 Blazer style front clip on truck as well
