Any 7.3 techs around?
Page 1 of 2 12 LastLast
Results 1 to 14 of 23
    Senior Member Sangersam's Avatar
    Folsom, California, United States
    Default Any 7.3 techs around?
    Her is my Buddy's truck not starting.......any ideas?
    IMG 0999 - YouTube
    world's oldest teenager Dkahnjob's Avatar
    West Hills, CA, Lake Havasu City, AZ
    Quote Originally Posted by Sangersam View Post
    IMG 0999 - YouTube
    That doesn't sound very good. I think it is HURT! How many miles on it?
    DKahnjob
    Barron Sprint,
    Hallett 270T "Kahn Job"
    180,xxx
    IT SOUNDS broken. iS THE OIL NORMAL OR OVERFULL AND FULL OF DIESEL? Sorry for the caps. I ain't rewriting it.
    Oil normal, fuels fine.....
    He has put a scanner on it, it is not throwing any codes.
    I suggested to change the CPS, he did, no change.
    The valve cover gasket clip has been changed, not it.
    He put in a new IDM 4 months ago, what are the chances that computer went out again? Does Ford have a warranty on them?
    Las Vegas, All Over..
    Whats the hp oil pressure at? the scan tool shoudl be able to tell you
    Senior Member David_396's Avatar
    Hanford CA
    My 02 7.3 did something like that after the hi pressure injection pump went out.
    Quote Originally Posted by Showrigger View Post
    They do not have one.
    Are you saying its a old idi or a powerstroke, if they hooked it up to a scan tool it should be a powerstroke which most certainly does have a hp oil pump, if the pressure is a little below what it takes to trigger the injectors or bouncing its will run like that.
    Edit i just watched the video again it, check the hp oil pump and ipr pressure.
    Quote Originally Posted by David_396 View Post
    All that white smoke is fuel......so I can't see it being that.
    We have a REAL scanner coming on Saturday, so we will be able to check all that then.
  13. #12
    it can be, the injector system requires a pressure to make the injectors atomize correctly, and if the hp oil pump is bouncing or the ipr is messing up, the dont work right and can do that..
    check out the ford man Technician High Pressure
    Pump Guide For The
    7.3 Power Stroke Engine
    here:
    DTS Articles - Coffee Table Books
  14. #13
    Check the hp oil pressure and injector buzz test, ill pm you my number if you have any questions let me know, i use a snap on Modis but i have used quite a few other with 7.3's and i have the factory service dvds if you need to help you..just dont anybody where you got them..
  15. #14
    Thank you! Our Buddy who is coming Saturday used to work for Ford in the diesel shop and is now the shop manager at IH here in Sacramento...........he has ALL the cool tools and knowledge to use it.
