5.9 Cummins plugged/dirty injector - Page 2
Page 2 of 2 FirstFirst 12
Results 15 to 18 of 18
  1. #15
    Lost Wages, NV
    Quote Originally Posted by southwind21 View Post
    03 shouldn't be common rail
    03 is a common rail. First year. HO was 305/555 rated. IIRC, standard output was 250hp and CA models were 235.
    Keith-
    Senior Member vdrivenman's Avatar
    se Texas Cajun Country
    Default 5.9 smoke
    also found a broken wire on tuner.fixed that and problem has been eliminated. thanks !
  4. #17
    Senior Member southwind21's Avatar
    Aug 2010
    texarkana tx
    Good deal ! Sorry been on vacation
  5. #18
    Default 5.9 smoke
    i greatly appreciate all the advice. this truck gets little to no use except when we travel or pull the boat.i do routine maintance per dodge spec's,but apparently that is not enough.truck only has 85,000 on it should be the last truck i ever had to purchase. wifey was/is the tuner installer and after it had a start up problem checked the tuner pins and actually found 2 broke wires. it needed the fuel filter change & a good cleansing anyways.
    thanks again
    vdrivenman
