Originally Posted by
Beer:30
Thanks for the kind words.
Benefits:
Less "wetted area" while traveling. The lower to the road you are minimizes any headwind. Stock or raised allows headwinds, or wind in general, to hit all of the suspension underneath. Wind speed is zero at the roadway surface.
Lower center of gravity. Obviously this helps with handling, but also towing. The taller a vehicle is, the more leverage the hitch has. If you bring the frame down to the same level as your trailer rails. If you see some of these lifted truck with fifth-wheel trailer-houses LEANING backwards EVEN WITH REAR AIR BAGS, it's the leverage of the trailer trying to pull the back of the truck down. Not good for steering. Front axle gets REAL light.
Loading materials/equipment: Would you rather LIFT your ice chests, tools, luggage and such up into the bed? Or just turn around and SET these items down.
Passengers tend to like to sit down into a seat, rather than JUMP up into a rig. My wife rode in my truck ONCE while stock. She said "I'm not riding in this thing again until you drop it!" This is also very helpful to door hinges. People tend to grab the armrest of the door panel and PULL themselves up into a lifted vehicle. Door hinges tend to wear pre-maturely.
Driveline angles: Have you seen the ridiculous angles of drivelines in lifted rigs? All we did on mine was flip the carrier-bearing up towards the cab floor. All of the u-joint angles came out the same as stock, just up-side-down. The driveline doesn't even know the difference.
With rear airbags, the load-carrying capacity is the same or MORE than OEM. My rear leaf springs are still in play - just augmented with the bags. I put a self-leveling compressor on this time. No more gauges or buttons. Load the truck or hook on a trailer - compressor comes on and makes the truck level again. Unload it or, let's say, put the boat in the water - the truck levels itself again. This way, anyone can drive it and they don't have to worry about how much air to have.
Maintenance: I would rather just lean into the engine bay for maintenance than climb up on a box. Much easier on the back and shoulders.
I'm sure I'm leaving a few things out.
