stroker kit for mpg?
Results 1 to 1 of 1
    sacramento
    Default stroker kit for mpg?
    460 split a cylinder & thinking about more comp & a stroker kit. with the extra torque will that give better mpg? ,4x4 ,4.56gears, gear vender ,37" tires,van . i heard that the compression will. & i remember getting more mpg when running 9.4 :1 comp. vs 8.8:1. one guy told me to run lower comp. & more timing & i have been doing that but 7mpg sucks. it must pass smog too! california makes it run on a wheel dyno . thanks for any info,turbo wog
