04 Silverado Cooling System Question
    Senior Member GottaJet's Avatar
    Santa Clarita,CA
    Default 04 Silverado Cooling System Question
    Hey Guys, I have a quick question about my 04 Silverado 5.3
    I want to drain my radiator and according to the Haynes manual there is a drain valve on the lower left of the radiator and even a nifty little hose to direct what your draining into a container. Well wouldn't you know it mine has a couple of barbs where the manual shows the valve but No valve and it has the little holders for the hose but no hose. Is this some kind of California anti pollution deal or what?. Am I going to have to pull the block plugs to drain this thing? Any help you
    Can provide will be greatly appreciated
    Shhh!! Can you hear that?? GJ
    New here Beer:30's Avatar
    Bakersfield, CA
    Just pull the lower hose. Messy, but that's about all you can do on newer ones.
    Make sure you're parked over a storm drain.
    Aug 2010
    look for something like this:
    they're usually located on the passenger side rear of the radiator. if you loosen it and you dont get water gushing out, take a small screwdriver and poke around in the hole. a lot of times theres a crust formed that blocks the drain and a little poke breaks it loose.
    if you cant find ANYTHING... lower radiator hose removal like mentioned above works too.
    Santa Clarita,CA
    Lol!! Thanks guys
