Duramax Diesel Mechanic Wanted
Results 1 to 10 of 10
    Senior Member 74 HOWARD 21RC's Avatar
    909 Alta Loma
    Default Duramax Diesel Mechanic Wanted
    Anybody know of a good Duramax mechanic in the Inland Empire?I have a leaking H2o pump.
    Senior Member JakeC.'s Avatar
    palmdale ca.
    your local dealer should have one there lol. im a lil to far to help you out. i would say do it yourself, but that is really difficult to do on a d-max. you have to remove the starter and put a flywheel holding tool in so you can break the harmonic balancer bolt loose.
    909 Alta Loma
    Yes I figured that one out. I can build a blower motor but I can change out my water pump.Just to lazy I guess.The dealership by my area is a joke.Thanks anyhow T.
    palmdale ca.
    yea if it wernt for have to take the harmonic balancer off it would be easy. but unless you have a way to keep the engine from turning over and a braker bar about 9 feet long then it aint going to happen. that mutha is tight!!! any question or need info on it let me know.
    Just Me snoc653's Avatar
    Eastern Iowa
    Quote Originally Posted by JakeC. View Post
    Can't you do the breaker bar on the harmonic balancer nut braced against the frame rail and then crank the starter trick? Should break the bolt loose. Re-torquing would be a biatch though. I didn't even think you needed to pull the starter if you had enough impact or bar to get the harmonic balancer off.
    Doctor Bomb
    Thumbs up
    Very good tech named Greg at Simpson GMC in Buena Park,
    They're authorized to do all warranty service on both Chevy/GMC
    He just started a DMAX club in O.C.: Diesel Trucks of Ca.
    Call 800-405-3614, ask for Jose to set up appointment with truck tech Greg,
    He goes by Stewietuned at TheDieselplace.com, hit him up over there with questions.
    FIRE IN THE HOLE!
    Senior Member Sig Ep Mock's Avatar
    Clyde at Redline Diesel. GM certified tech. Good guy.
    Redline Diesel Performance Llc
    1787 Pomona Road
    Corona, ca 92880-6995
    Phone: (951) 734-2700
    Chris
    palmdale ca.
    you could try the breaker bar against the frame and cracnk but it doesnt always work. i have also been able to pull the acess cover on the trans and you can stick a foot long prybar in and lock the engine up by the torque converter to flywheel mounting tabs. this will let you break the bolt loose and retorque it. thats the fastest way i have figured out how to do it without pulling the started.
    Yucaipa, California
    Default Mechanic
    Quote Originally Posted by 74 HOWARD 21RC View Post
    I have a ford, but i have had nothing but great experiences with Trans West Truck Center in Fontana....right at the 10 and Cherry. They work on big trucks usually..have some real mechanics there..not some kid with an SCE patch on his shoulder. They will negotiate prices too..they're not on a dealer 99.21 dollars an hour schedule.
    1992 Eliminator Daytona 21'
    Steady Rollin
    Corona
    Quote Originally Posted by Sig Ep Mock View Post
    1787 Pomona Road
    Chris
    I second Clyde!
    Hes the only other person besides myself who has wrenched on my truck.
    -Scott
