04 colorado
Results 1 to 8 of 8
04 colorado
    Member dgie's Avatar
    Default 04 colorado
    I bought a 04 Colorado with a standard 5 speed and a 4 cyl vortec engine. The tow rating seems low, I think it said something like 2500 lbs. Can I tow my jet boat with it? 18ft 455 olds do not know the exact weight.
    Formerly CMac Premonition's Avatar
    Phx
    Question is, can you stop it?
    Thats the biggest deciding factor in ratings.
    http://i105.photobucket.com/albums/m240/cmacci/Signature-Avatar.jpg
    Quote Originally Posted by Premonition View Post
    good point
    Member flat bottom crazy's Avatar
    San dimas
    You should be able to tow it....we tow our 17ft poty flat bottom with a 427 in it just fine.
    Quote Originally Posted by flat bottom crazy View Post
    you have a colorado 4 banger standard shift also?
    San dimas
    ours is auto 5cyl
    The towing capacity of the I5 is greater, not sure why the 4 banger is rated so much lower. I plan to try it anyways.
    San dimas
    You still shouldn't have a problem with it just know your limits and use greater distances.
