Towing Double
Results 1 to 7 of 7
Towing Double
    Senior Member Luvnlife's Avatar
    Acton, Ca
    Default Towing Double
    We were on our way home from Bakersfield Raceway on Sunday morning and I see a guy going the other way with an overhead camper pulling two tag trailers. One was a boat and the second was a jetski trailer As far as I know this is illegal in Cali. So what's the deal? Is he a newbie and hasn't been caught or does he just do it till pulled over then unhooks one then recouples in a parking lot when the CHP is gone. It was on the 5. Just thought it was interesting
    New here Beer:30's Avatar
    Bakersfield, CA
    With a doubles endorsement on a Class-A, you can tow any combo as long as the first trailer has brakes.
    EDIT: ....and it doesn't exceed 65 feet.
    Senior Member vee-driven's Avatar
    Lomita so. cal.
    But will they pull you over for no reason just to check and see if you have the endorsement? And whats the deal with pulling a 5th wheel and a tag behind that, same as a tag tag?
    It's not that i don't care, I just dont give a sh!t!
    Bakersfield, CA
    Quote Originally Posted by vee-driven View Post
    Technically, yes. The fifth will always have brakes, so that part is already handled. Still need a Class-A.
    Acton, Ca
    You are right. I didn't think of that scenario
    Yucaipa, California
    they are right...the first trailer does not have to be fifth wheel. But to stop you they need probable cause...they would need another reason. I'm sure if you're towing doubles..you'll weave enough for an officer to stop you. But they can't just stop you to inspect.
    1992 Eliminator Daytona 21'
    Banne'd Cobra1's Avatar
    It's in the way it is towed, 5th hitch vs. bumper pull. The 5th is much more stable. You can only pull a tag behind a 5th wheel trailer in az, with brakes on the 5th. Sad part is you don't need an A to do it. You guys get so screwed in Cali. The DOT is run by a bunch of idiots.
