[Question] Thinking about buying a M1028A3
Results 1 to 12 of 12
    Member Batzen's Avatar
    May 2012
    Stuttgart / Germany
    Default Thinking about buying a M1028A3
    Hey guys, i have the opportunity to buy a Chevrolet 4x4 K30 dually.
    Almost rust free with 26000 miles, 1984, 6.2 Diesel.Was an us army airfield snowplower.
    Will give it a visit this week, what do i have to look at?
    What do i have to know about this truck?
    Just want it for fun use, and of course towing 16'-20' Boats sometimes.
    Does this thing really only do 55 mph? What does it need to make it a little faster, want it to about 62 mph easy?
    Senior Member lbhsbz's Avatar
    Long Beach
    No, it probably won't do 55mph with that motor. Register it as a diesel and then throw a Big Block in it, or a 5.9 cummins. Then you'll have a tow rig
    Senior Member Mash on It's Avatar
    Willow Beach & BHC
    Default 6.2
    lbhsbz- I believe he is in Germany, Not too many BBC's and 5.9's there, I bet. (Diesel prolly $10 a gal too) As far as the 6.2, with 4.56 gears, 4 speed trans, and a 235/85/16 tire, should run to the mid 60's, However, the U.S Army may have it governed to 55 mph. It would tow a 20 ft boat fine, slow, but fine. Daniel
    "Never mind the mule, Just load the wagon"
    '76 Eliminator 21'
    runnin the river
    Put it on 35" tires n it will run 70. I know for a fact
    Diesel Pimp WINspeed's Avatar
    Aug 2009
    East Bay, ca
    The fuel screw is easy to get to on that pump, give it a half turn and advance the timing a little(Both easy to do.) You can turn them up quite a bit, But install a pyrometer. That's the diesel we started modding in the 80's, I was a teenager helping my dad do this stuff. They'll make pretty good power.
    May 2012
    Stuttgart / Germany
    Thanks for the help.
    The Owner decided not to sell it in the end.
    Senior Member uniboarder's Avatar
    Dec 2012
    The most important thing to check on snow plow trucks is the frame! They seem to twist when repeatedly getting rammed into snow banks!!!
    May 2012
    Stuttgart / Germany
    Bought it, finally.
    But it definitaly needs bigger wheels.
    Just Me snoc653's Avatar
    Eastern Iowa
    Quote Originally Posted by Batzen View Post
    Bought it, finally.
    Things to remember: It's 24 volt unless it's been converted. Yes, it will run mid 60s which by now you know. The problem with that engine was if you put to much load on it during a decel it will stretch the head bolts. The dash is 24 volts also. The radio fuse, if I remember correctly is still 12 volts if you want to check it and tap in there for your accessories.
    EDIT: Just noticed you in Stuttgart, are you at Patch or Echterdingen? Didn't they close most of the other bases? If you're at Echterdingen is Snoopy's still there?
    May 2012
    Stuttgart / Germany
    Hey snoc. I'm a local german, i don't know much about the US Bases here. Thank you very much for the Information. This thing needs a radio.
    Gesendet von meinem GT-N7000 mit Tapatalk 2
    May 2012
    Stuttgart / Germany
    Hi guys, now it does 65 easy.
    Now its definately time to finish the boat project!
    Yucaipa, California
    Hey, just saw this thread. That thing is sweet man!
    1992 Eliminator Daytona 21'
