Ladder Bars
Results 1 to 6 of 6
Ladder Bars
    Senior Member BLOWN HOWARD's Avatar
    Default Ladder Bars
    Looking for a set of ladder bars for my 2004 CC Chevy.
    Senior Member Sig Ep Mock's Avatar
    Now what are you doing?
    Are you going for the look or do you have axle wrap that bad? I played around with quite a few set-ups on my CC Chevy and ultimately ended up four linking the rear with bags but not because of axle wrap. Did you get the Deaver springs?
    Chris
    Come on you know me i cant leave anything alone. Actually i have some serious axle wrap. When i tow the toy hauler it is rediculous. Have been looking at some kits from 350 all the way up to 1200. How did you 4link come out?
    Quote Originally Posted by BLOWN HOWARD View Post
    A lot of $$$ and work but it worked awesome for controlling the axle but never stopped the dreaded freeway bounce when empty. Did you ever get the Deavers and Carli long travel bags? With the Deavers and Bags aired up I would think the axle wrap wouldn't be that bad.
    I looked at a lot of traction/ladder bars and realized I could be a better set for less money and they would work better. I think the best set I saw were from ORU but I think they are discontinued. The Fabtech ones look good too. Basically you want to keep the axle from twisting but still be able to travel forward and back as the srping arches and flattens. The bars that are fixed at both ends are bad and bind the suspension. You want one the is tied to the axle and rotates/swings at the frame side.
    http://www.rockymountainsusp.com/tractionbars.htm
    If you find a set you like I can help install or we can build you a set if you feel like spending a weekend working on them. Let me know,
    Chris
    I was going to run the carli long travel bags but i talked to them and they dont offer a kit yet for the chevy. So i held off on the deavers. Pretty much i hope to just get a way with running some ladder bars. Shoot i gots lots of free weekends to build a set. Let me know if you wanna tackle it.
    Shouldn't take more than a day to fab a set up. Between T Day and xmas I should have time and we can put a set together.
    Chris
