T-case won't go into neutral
Results 1 to 3 of 3
    I'm baaaaack... hkunz's Avatar
    Lake Havasu
    Default T-case won't go into neutral
    OK, so we've tried the instructions in the manual, and it reads exactly like described above. We've also tried rolling, on the towbar, going forwards and backwards, pointing uphill and pointing downhill. We have a 2007 Ram 3500 single wheel Megacab 4x4 with the 5.9L Cummins and automatic. The truck has about 65,000 miles on it. We've been using it to tow our 30' boat and 26' enclosed car hauler for years. This last year we downsized, sold our Wrangler, and got a massive towbar for the Ram. The towbar works great, the instructions worked the first time, but now we've had no luck on engaging neutral on the t-case so we can tow it. My wife had to drive it a few times rather than flat tow because we couldn't get it into neutral. We towed from Havasu to Williams no problem, but on the return trip it wouldn't go into neutral no matter what we did. We stopped in Hackberry (on the old 66) and it went right in. Twice. Now on the current trip, it wouldn't go in at Havasu, Kingman, or Williams.
    Is there something that needs a tap with a hammer, is there a connector I need to check, anything? I have difficulty getting up and down with my bad hips, so prefer a direct approach that I can take care of in one fell swoop, if possible.
    It is impossible to defeat an ignorant man in argument. -William G. McAdoo, lawyer and politician (1863-1941)
    07 Advantage X-Flight 600 SCi Bravo 1 XR
    04 Cheetah Scorpion 6.2 Bravo 1 - SOLD!
    96 Donzi 21' 454 Bravo 3 Medallion - gone!
    72 Tahiti 16' 468 Olds Berkeley jet - SOLD!
    11 RZR XP, 08 Polaris Scrambler, 06 Rhino, 06 Joyner 650 dune buggy, 04 KFX 700
    Senior Member roughneck427's Avatar
    Apr 2014
    Fresno CA
    Do you have any friends with a snap on scanner or equivalent ?? I see your in Bakersfield if you come towards Fresno i can scan it and see what the deal is. Heres a troubleshooting deal i got from mitchell on demand
    Lake Havasu
    Quote Originally Posted by roughneck427 View Post
    We're at the North Rim of the Grand Canyon, so it's a bit of a haul, but thanks. I found that the brake lights weren't coming on, either, so i checked the wires under the dash. A little wiggling, and both the brake lights and the neutral switch worked. I plan to dig in a bit more when we get home to Havasu. (guess I forgot to update my profile)
