Drivers side A/C -07 duramax
Results 1 to 3 of 3
    031 RIVER4FUN's Avatar
    Default Drivers side A/C -07 duramax
    Cruising down the road with A/C on, drivers side goes hot, passenger side stays cool.
    Pull over, shut motor off, start back up a/c is cool. Could stay that way for days or 10 minutes. I've actually got pretty good at 65 mph, slip it into neutral, shut off motor, start it back up & keep on going. Opinions?
    Senior Member OLD MAN ON THE LAKE's Avatar
    Phoenix
    Distribution sellinoid or motor is shot. Common problem.
    Feb 2009
    Houston
    Default Computer Restart Without Restarting Engine
    I don't know if the'07's will let you do it like my '01 will, but you don't have to kill the engine to reset the computer. With the engine running and in gear (vehicle not moving and foot on brake), bump the key into the start position. This will cause the computer to reset without the wear and tear on the battery and starter. Chevrolet was smart enough to program the truck to not let the starter engage while the truck is in gear.
    As for your actual issue, this is a known problem and unfortunately requires the dash to be removed to replace a solenoid.
