Fuel in my oil
Results 1 to 2 of 2
Fuel in my oil
    Default Fuel in my oil
    I have an 06 Dodge 5.9 diesel pickup. I'm getting alot of fuel in my oil. Any ideas? Truck has 58,000 miles. Thanks Bill
    Senior Member JakeC.'s Avatar
    palmdale ca.
    I'm not real familiar with the cummins, I mainly work on the duramax. But believe that you truck uses a common rail fuel system that runs under the valve cover. Chances are that you have a fuel line leak or an injector/injector seal leaking. May need to pull the valve cover and see if you can find where it's coming from.
