Chevy Techs?? 04' Powersterring.......
Page 1 of 2 12 LastLast
Results 1 to 14 of 19
    @ The Islander OutCole'd's Avatar
    Vegas
    Default Chevy Techs?? 04' Powersterring.......
    Same truck, same problem I've been fighting forever. No power steering at idle with brake applied.
    At the dealer now, Thanks for extended warranties!! First they replace the control valve, said it's fixed, come and get it. I show up, no power sterring still. I get my writer out there to look at it, "yep, no power sterring, don't worry about it, we'll take care of it."
    Next dart throw, replace pump. I get the call, go down and same thing. He shows me a bulletin basically stating it's normal. Please, no power sterring is normal?
    Any other suggestions? I've been on a few truck forums, but really no help. 04' with 55K miles, 285/16 tires. I'd hate to have to get rid of already.
    Can I lemon law it if it's out of warr if they can't fix it?
    <img src=http://www.performanceboats.com//signaturepics/sigpic640_1.gif border=0 alt= />
    they have a redesigned steering gear that has bigger valves in it so that when the hydraboost brakes are applied, the gear can operate as normal.
    is this by chance a 1500hd or 2500hd? there's also a newer design ps pump with a bigger pressure volume too. let me know, i'll straighten it out from 2k miles away
    s480@18lbs nto 325cubes of whoopass : ) turbo boyz
    print this out and take it to your dealer, tell em their dumb __cks and that a mastertech okie 1000's of miles away diagnosed it for ya
    Subject: EI06002 - 670 Gear Box Power Steering Pump, P/S Performance Concerns
    Models: 2003-2006 Cadillac Escalade, Escalade ESV, Escalade EXT
    2003-2006 Chevrolet Avalanche, Suburban, Tahoe
    2003-2007 Chevrolet Silverado Classic
    2007-2008 Chevrolet Silverado, Suburban (2500 Series Only)
    2003-2006 GMC Yukon, Yukon Denali, Yukon XL
    2003-2007 GMC Sierra Classic
    2007-2008 GMC Sierra, Yukon XL (2500 Series Only)
    This bulletin is being revised to add model years and models. Please discard Corporate Bulletin Number 05-02-32-008A (Section 02 -- Steering).
    Condition
    Some customers may comment on a lack of steering assist when stopped or during parking lot type maneuvers. A lack of steering assist could occur if the brakes are applied and turning the steering wheel with the vehicle stopped or during parking lot type maneuvers. This condition will go away or greatly improve once vehicle begins to move or is above parking lot speeds. This concern can be aggravated by worn tires, low tire air pressure, low power steering pump pressures, and tires larger than stock size.
    Correction
    Important: In all cases, it is recommended that the proper tire size and the maximum tire pressure is set according to the manufacturer’s specification as noted on the door placard; especially for the front tires.
    Perform the "Power Steering System Test" found in SI. Make any necessary repairs based on system diagnosis.
    1.1. FOR 2500 AND 3500 VEHICLES ONLY - If diagnostics did not lead to any repair, this concern is a normal operating characteristic. No further repairs should be made. A Field Product Report should be submitted - refer to Corporate Bulletin Number 02-00-89-002D.
    1.2. FOR 1500 SERIES VEHICLES ONLY - If diagnostics did not lead to any repair, this concern is a normal operating characteristic.
    If the vehicle is equipped with a 670 gear box, replacing it with a 680 gear box may increase the customer satisfaction.
    To determine if the vehicle is equipped with a 670 gear box, inspect the mounting bolts that attach the stub shaft housing. A 670 gear box will only have 3 mounting bolts. If the stub shaft housing does not have any mounting bolts or has 4 bolts - DO NOT PROCEED WITH THIS BULLETIN. The vehicle is not equipped with a 670 gear box.
    If replacing a 670 gear box with a 680 gear box, it will be necessary to replace the power steering gear, union fitting and both inlet O-ring seals.
    Parts Information
    Part Number
    Description
    88965542
    Power Steering Gear
    26025709
    Union Fitting
    26001594
    Inlet O-ring Seal
    Warranty Information
    Vegas
    2500 And what airlines would you like to use??
    Vegas
    Condition
    Correction
    Parts Information
    Part Number
    Description
    88965542
    Power Steering Gear
    26025709
    Union Fitting
    26001594
    Inlet O-ring Seal
    I'm afraid if I show them that, that they will say it's normal. How can no power sterring be normal?
    i've seen this more than once i put the newer design steering gears on and it FIXES them. if you're under warranty still, just print off the bulletin i posted, take it to the dealership and tell them you talked to a gm mastertech from okla that has seen it many a time and that the steering gear upgrade repaired them allllllll. the steering gear p# is 88965542 . it will fix you bud, i wouldn't send ya on a goose chase 90% of the trucks i work on have hydraboost like your's , i'm veryyyyy familiar with that system.i've seen 2500's with the lil gear box.
    Vegas
    OK, I just got off the phone with my writer, he is saying I have the newest gear box on my truck 19150315
    I sent him the info you gave me, lets see what he comes back with.
    Thanks for your help!!
    Quote Originally Posted by OutCole'd View Post
    not a good number, maybe he meant 19150135 which is the only stock 1 showing, which is the lil gear
    Vegas
    I bet you are right. If you fix this, I'm putting you on my xmas list.
    Yucaipa, California
    Impatient 1, can you please fix my Ford F350 powerstroke 7.3, i have this same problem Makes backing the trailer into a tight spot on a grade a real "EM EFFER"
    1992 Eliminator Daytona 21'
    Vegas
    No update from my truck. I talked to my writer Friday afternoon. He said he is waiting for Chevy to get back to him. They are opening a case on it or something.
  13. #12
    ptz
    ptz is offline
    so ca
    Red face
    does GM still have a 1 800 number for regional zones
    for customer service ?
    what if you find another dealership that actually reads the tech bulletins ?
    they do print them in multiple languages ?
    i know that might be rare ,since most GM dealerships are like pumpkin lots in February.....can't even get a salesman to come out to the curb..
    if they opened a case, maybe you already on the lemon highway..
  14. #13
    Senior Member JakeC.'s Avatar
    palmdale ca.
    i too as a tech have seen this problem many times, including my own truck. and the new steering geer has fixed it every time. if that dealer keeps jerkin you around, try and take it sonewhere else and show them the bulliton and let them fix it for ya.
  15. #14
    Vegas
    Quote Originally Posted by JakeC. View Post
    Thanks, I should know what they say Monday, I hope they just get it done.
