Trailer reflector tape
Results 1 to 3 of 3
    Livin in daily fasination WyattG's Avatar
    Jul 2015
    From the Sierra Foothills to the streets of San Francisco
    Default Trailer reflector tape
    I have min reflectors and lighting on my 31' aluminum boat trailer per boat US). However, I have noticed that many trailers in general around this length has reflective tape the length of the trailer (for the most part).
    Is this a requirement for certain length trailers in certain states or is this a extra safety requirement???
    I checked the gov site, but failed to find reflector tape req/info
    I trailer in Calif and Nev.- non commercial non sponsored boat.
    thanks
    THE LEGEND Mouzer's Avatar
    corona ca
    Introduction – Trucks exceeding 10,000 pounds and over 80 inches wide must mark their trailers with 2″ wide DOT C2 reflective tape that alternates white and red. (white looks silvery in the daytime). A 6/6 (6″ red and 6″ white) or a 7/11 (7″ white and 11″ red) pattern can be used. 50% of each side must be covered. (even distribution) In the rear, two strips must be used in the lower rear and an inverted L using solid white must mark the top corners of the trailer. Trucks must be marked in a similar fashion. See pictures at the bottom of this page.
    (This is a summary of the regulation. For an exact copy of the law you can refer to the actual FMCSA document)
    The FMCSA has set up regulations requiring the use of conspicuity (reflective tape) materials on trailers and the rear of truck tractors. The rules are in place to help reduce the incidence of motorists crashing into the rear or sides of tractor trailers at nighttime and under other conditions of reduced visibility. Also to reduce the incidence of motorists rear ending truck tractors (under operation without trailers) under the same types of conditions.
    On December 10, 1992, the National Highway Traffic Safety Administration or NHTSA published a final rule requiring that trailers manufactured on or after December 1, 1993, which have an overall width of 80 inches or more and a gross vehicle weight rating (GVWR) of more than 10,000 pounds, (with the exception of pole trailers and trailers designed exclusively for living or office use) be equipped on the sides and rear with a means for making them more visible on the road. The NHTSA ruling allows trailer manufacturers to install either red and white retro reflective tape or sheeting or reflex reflectors. This tape is commonly referred to as DOT C2 reflective tape and is thus marked for easy identification
    Locations for Conspicuity Treatment
    The following is a description of where the conspicuity treatments need to be located on trailers. Images of conspicuity treatments on some common types of trailers are provided at the bottom of this page.
    Sides of the Trailer
    The 2″ DOT C2 retro reflective sheeting need to be applied to both sides of the trailer or semitrailer. Each strip of retro reflective sheeting must be positioned as horizontally as practicable, beginning and ending as close to the front and rear as practicable. The conspicuity treatment is not required to be continuous. However, the sum of the length of all of the segments must be at least half of the length of the trailer and the spaces between the segments of the strip must be distributed as evenly as practicable. The centerline for each strip of retroreflective sheeting (or reflex reflector) must be between 375 mm (15 inches) and 1,525 mm (60 inches) above the road surface when measured with the trailer empty or unladen, or as close as practicable to this area. If necessary to clear rivet heads or other similar obstructions, 50 mm (2 inches) wide retro reflective sheeting may be separated into two 25 mm (1 inch) wide strips of the same length and color, separated by a space of not more than 25 mm (1 inch).
    Lower rear area of the Trailer
    The rear of each trailer and semitrailer must be equipped with retro reflective sheeting (or reflex reflectors). Each strip of retro reflective sheeting (or reflex reflector) must be positioned as horizontally as practicable, extending across the full width of the trailer, beginning and ending as close to the extreme edges as practicable. The centerline for each of the strips of retro reflective sheeting (or each reflex reflector) must be between 375 mm (15 inches) and 1,525 mm (60 inches) above the road surface when measured with the trailer empty or unladen, or as close as practicable to this area.
    Upper rear area of the Trailer
    Two pairs of white strips of retro reflective sheeting (or reflex reflectors), each pair consisting of strips 300 mm (12 inches) long, must be positioned horizontally and vertically on the right and left upper corners of the rear of the body of each trailer and semitrailer, as close as practicable to the top of the trailer and as far apart as practicable. If the perimeter of the body, as viewed from the rear, is not square or rectangular, the conspicuity treatments may be applied along the perimeter, as close as practicable to the uppermost and outermost areas of the rear of the body on the left and right sides.
    Rear of Truck
    On August 8, 1996, the NHTSA published a final rule requiring that truck tractors manufactured on or after July 1, 1997, be equipped with red-and-white retroreflective material similar to that required on the rear of the trailers they tow to increase nighttime conspicuity. Manufacturers may choose either retroreflective sheeting or reflex reflectors. In the case of truck tractors delivered with a temporary mudflap arrangement rather than permanent equipment, the requirement for retroreflective material near the top of the mudflap may be satisfied with material carried by the temporary mudflap brackets that are transferable to the permanent mudflap system. Retroreflective material is also required near the top of the cab in a pattern similar to that used on trailers.
    UNDER MENTAL HEALTH LOCK DOWN .....
    "TEAM MOUZER" ...........need a P.I ,body guard,fugitive recovery,stalker problem,cheating spouse.........pm mouzer
    Jul 2015
    Default should be a sticky IMHO.
    Mouzer,
    Good stuff, this summary you provided pointed me in the right direction to find the full detailed info in the DOT gov site.
    The actual details in the Fed Dot FMCSA document if you drill down in the gov. section especially footnote 9 was particularly enlighting as many trailers do lack some req equip when it comes to amber lighting etc if past a certain width from the towing vehicle and other little things can keep LE focusing on other important things rolling on our highways. There appears to be many key words on the official DOT site, weight, use etc. Additionally, I guess there is much to say if you have a rolling billboard of your 'favorite thang' that could move you from recreational over to commercial if things hit the fan and you are in talks with your insurance co. or worst. The little things can trip one up eh?
    Again thank you, this was very helpful.
    Make it a great day!
