Hey GM techs
Results 1 to 8 of 8
Hey GM techs
    Senior Member Luvnlife's Avatar
    Acton, Ca
    Default Hey GM techs
    My wife tells me that she smells tranny fluid on our 03 2500HD, Duramax Allison. I smell it also. Look for leaks, none. Was not quite ready for a trans service but I changed the fluid anyway. Smell went away for a few days then returned. I have an appointment to drop it off but wanted to hear some input. Thanks
    Senior Member 030GUILTY's Avatar
    Feb 2009
    Paso Robles
    Default G M
    BUY A FORD///////////// LIKE YOUR WORK TRUCK
    the frt pump bolts seals are prone to leak on those trans, there for awhile i was pulling out allisons left and right replacing pump bolt seals.
    New here Beer:30's Avatar
    Bakersfield, CA
    Also check the power steering lines. At that age, it would probably be time for hoses to start leaking. PS fluid is very similar to trans fluid - smell the same, and would be ahead of the exhaust where it would burn and make the smell worse.
    CLASSIC HOTBOATER wideopen's Avatar
    ROANOKE VA
    my 06 has leaked up front at the cooler they had a recall on the lines
    had them done 3 times
    also power steering hose to the brake booster they also have a recall on bad hoses
    Acton, Ca
    Quote Originally Posted by 030GUILTY View Post
    Well that power steering hose went at 60,000 and there were no replacements because of bad parts
    Acton, Ca
    Seems there might have been a small leak at the oilfilter I saw. Changed it and the smell went away. I did notice however there was some sweat from a power steering hose that I will keep an eye on and replace. Thanks guys. Cale
    Bakersfield, CA
    Quote Originally Posted by Luvnlife View Post
    That's what I figured.
    Ya better keep going. At that age, I would start collecting parts. Serp belt, water pump, stationary idler pulleys and the tensioner. All of this would need to be freshened at you age. I did all of that to my '98 at 7 years old/75,000. Better to spend a little now - than thousands later when one or all of that goes half-way between Havasu and the tow truck has to come out.
    When the water pump is off/empty, it is a great time to go through the radiator and put all new rubber hoses. Beats blowing a head gasket.
    Just my $.02
